Sponsored by: Real Truck
7.3 powerstroke gpr
Old Dec 3, 2021 | 06:37 PM
7.3 powerstroke3456's Avatar
7.3 powerstroke3456
7.3 powerstroke gpr
What is the best aftermarket glow plug relay for my 2001 7.3 to start in the winter put new glow plugs and a new relay and its only a little better. I did some research and found they made upgraded gprs, so what is the best option for my truck to get it to start in the cold? Thank you all for any help.
Old Dec 3, 2021 | 08:16 PM
Evan_P's Avatar
Evan_P
Motorcraft.
Old Dec 4, 2021 | 11:14 AM
cj45lc's Avatar
cj45lc
If you look on the 7.3 forum there is quite a bit of talk about the relays. The White-Rogers was what everyone said was the hot ticket for awhile but now it seems there is one that is used on snowplows & stuff that folks are using I believe it's called Trombetta.
Old Dec 4, 2021 | 05:24 PM
Td63's Avatar
Td63
One thing check as well is your wiring and glow plugs. when I had problems with my solenoid it was often because I had wiring or glow plug issues which caused the relay to have an excessive amount of current flowing through it. Which in turn contributed to it burning up. The relays are marginal at best. when several glow plugs are out it causes the remaining ones to heat up quicker increasing the amp draw. Damaging the relay as well as burnt connections at the under valve cover harness connection
Old Dec 24, 2021 | 09:12 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
https://www.ford-trucks.com/forums/1...l#post19172939
Old Dec 28, 2021 | 07:21 PM
Brother Les's Avatar
Brother Les
You put on a new Glow Plug Relay. You put in new Glow Plugs.... are they all coming on?
I believe that you are ok....
But... have a very good set of batteries. have them load tested.
Old Dec 28, 2021 | 07:41 PM
Just Strokin's Avatar
Just Strokin
NAPA use to make a good one. Think the part number is GPR109.
Old Dec 29, 2021 | 07:42 AM
Brother Les
I have this (GPR 109), 3 year and 36,000 mile warranty.
Old Dec 29, 2021 | 09:46 PM
Picky1962's Avatar
Picky1962
I just installed a new starter and Trombetta gpr and it's a whole new world. For years I've kept in plugged in because it just sucked once the temps dropped below 40 F. I'm actually looking forward to this weekend because the temp is droping into the single digits and I want to see the real difference. I've got a 2002 7.3 with 210,000 miles and have never changed the gpr before.
Jimjoe
Sep 7, 2018 01:55 PM
Nick91
Mar 2, 2014 08:40 PM
VRC9170
British Columbia
Oct 31, 2009 10:57 AM
PAVEMENTMAN
Jul 23, 2009 09:55 AM
northernlights
Jul 23, 2006 12:35 AM
