Sponsored by: Real Truck
Cold start 7.3 diesel
Old Aug 31, 2018 | 08:08 PM
Jimjoe's Avatar
Jimjoe
If anyone can help I have an 01 f250 7.3 that will not start below 30 degrees F, had glow plugs,block heater checked and batteries are practically new. Above 30° truck will fire right up,any ideas
Old Aug 31, 2018 | 08:10 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Hows the glow plug relay and fuel bowl heater
Old Aug 31, 2018 | 10:52 PM
Geno C's Avatar
Geno C
Glow plug relay most likely. I went through one per year with my Excursion
Old Sep 1, 2018 | 07:35 AM
Jimjoe's Avatar
Jimjoe
I give it a look thanks
Old Sep 7, 2018 | 01:55 PM
thomabb's Avatar
thomabb
Hold the leads to a volt meter across the two large studs on the glow plug relay. Have someone turn the key to ON. The voltage across the relay will drop to near zero when the relay engages, then come back to battery voltage when the relay clicks off.
Note - if you have a California truck, you may have a glow plug control module instead of a relay.
sunuvabug
29
Mar 10, 2019 11:16 PM
Supa Duty
Mar 5, 2014 08:46 PM
SILVER STROKE
Mar 17, 2011 08:57 PM
shoes55
Jan 7, 2004 07:15 AM
rafterjf250
Sep 4, 2002 07:21 PM
