B & D SEIC install
Old Oct 6, 2021 | 05:03 PM
powerboatr's Avatar
powerboatr
B & D SEIC install
Sit down folks, took all of 45 minutes, 30 of that was me fishing my fat hand behind a wire loom to grab the connector
i placed mine in the little glove box, with dial white line facing out.
tested it and right off the "ON" detent it jumped to just about 800-900 and then as i rotated the ****, it did what was advertised, although there was a delay of about 1/4 second from turning the **** to actual idle change
tap brakes it went to idle like RIGHT NOW.
i am happy
and yes i put it in the small glove box as it wont be needed everyday and it kept the lower knee panel clean.
i didnt put the silly decal behind the **** as i know to turn up the idle it rotate it ....well clockwise and up plus if i see the white line, then i know its in the "OFF" position
Old Oct 6, 2021 | 06:46 PM
4df150's Avatar
4df150
Nice job.
When I did the high idle in my F-250 I got a switch, a variable resister and wired it up myself. Works like a charm.
Old Oct 8, 2021 | 07:08 AM
slowmans's Avatar
slowmans
Clean install, how much is it?
Old Oct 8, 2021 | 07:45 AM
Overkill2's Avatar
Overkill2
Nice install Bob. Good job...
I think they are about 75 to 80 bucks for the kit.
Old Oct 8, 2021 | 07:41 PM
Just Strokin's Avatar
Just Strokin
Before Radio Shack went belly up, you could get a rheostat for a few bucks and do similar...glad to see someone picked up where RS left off and offer this item even if the cost is more.
Old Oct 12, 2021 | 04:57 PM
riverratrusty's Avatar
riverratrusty
Nice! I have the same but put my dial on the right hand screw to the ODB port. No one but me knows it's there and I just reach down 't and feel for the click to know if it is on or off.
Old Oct 14, 2021 | 07:41 PM
slowmans's Avatar
slowmans
So with the b&d kit you lose the pig tail for the upfitters?
Old Oct 14, 2021 | 08:57 PM
4df150's Avatar
4df150
This is how I did my SEIC on my '13. I picked up the main power from the 12v power plug.
Old Oct 15, 2021 | 11:09 AM
Overkill2's Avatar
Overkill2
That's actually not a bad idea. Leaves 4 outfitter switches instead of 3 if someone has plans for them all...
Old Oct 16, 2021 | 07:03 PM
powerboatr's Avatar
powerboatr
no. The upffitters are not used with the kit. It plugs into the factory seic harness already hooked up
Old Oct 17, 2021 | 07:01 AM
slowmans's Avatar
slowmans
yes but the harness you remove to plug in the BD harness is your up fitter wiring harness isn’t it? If so you don’t have any other way to hook up anything to your upfitter switches
Old Oct 18, 2021 | 05:30 PM
powerboatr's Avatar
powerboatr
nope. It has zero to do with upffitters switches or harness. It's simply plugs into stock already added from Ford the seic harness and system. Yes some use an upfitter switch with a resistor plugged in to the seic harness. But the BD. Harness only uses the stock seic harness.....not the upfitters
Old Oct 18, 2021 | 07:47 PM
slowmans's Avatar
slowmans
oh so that factory harness is in addition to the upfitter wiring? I was confused as to why they would omit the use of the upfitter switches …. Thanks for the info!
JayCarver
Jul 30, 2021 07:34 PM
scrdanis
Feb 22, 2011 12:22 PM
ztodd377
Nov 3, 2008 05:32 PM
nhbound104
Jan 9, 2008 10:48 AM
hennjj
Nov 5, 2003 04:55 AM
