BD High Idle Install Location
Old Jul 30, 2021 | 09:46 AM
JayCarver's Avatar
JayCarver
Thinking about getting the BD high idle kit with the **** to adjust the rpm.
Would love to see some pics of where others have mounted the **** for a clean look.
Thanks!
Old Jul 30, 2021 | 10:03 AM
AlbertaHooter's Avatar
AlbertaHooter
Thanks!
I believe I saw a video where someone installed the **** inside the little glove box. Seemed like a good idea - out of the way but yet still accessible. Let’s face it, it’s not like you’ll be fiddling with the **** everyday…
I’d even consider mounting it up underneath the dash completely out of sight and where you won’t accidentally kick it or inadvertently turn the ****.
Old Jul 30, 2021 | 10:06 AM
JayCarver's Avatar
JayCarver
I agree that is a good spot, however I have a 2way radio mounted in that upper glove box.
Also agree that somewhere out of sight might not be a bad idea either.
Still would like to see what others have come up with.
Old Jul 30, 2021 | 10:42 AM
ford390gashog's Avatar
ford390gashog
The **** is also the on/off switch. Unless you want to cycle the ignition. It should be easy to reach, I probably hit mine on and off 40 times a day. Mine is to the left of the steering column on the flat part of the gauge bezel.
Old Jul 30, 2021 | 11:23 AM
JayCarver's Avatar
JayCarver
Good point, I like that location.
Old Jul 30, 2021 | 12:10 PM
Frank79's Avatar
Frank79
Isn't this the same concept as someone installing a resistor inline somewhere near the passenger foot area?
Thought I saw a few posts about that and they used a up fitter switch to turn off/on the high idle.
Old Jul 30, 2021 | 12:23 PM
JayCarver's Avatar
JayCarver
Exact same except this is plug n play and adjustable.
Old Jul 30, 2021 | 07:34 PM
Je942010's Avatar
Je942010
I have mine tucked up under the dash.
nico963
6.7L Power Stroke Diesel
Jun 11, 2021 12:33 PM
cpobst
Nov 20, 2020 07:05 AM
Midnight Ride
Jun 15, 2013 06:05 AM
1ford1
Aug 19, 2006 12:40 AM
