Sponsored by: Real Truck
Tailgate lock mechanism
Old Oct 3, 2021 | 01:14 PM
Cliff67's Avatar
Cliff67
5th Gear
Had a hiccup yesterday with the lock mechanism on my tailgate, the key did nothing. Had to remove access plate to manually unlock and while in there found a plastic plate that somehow uses arm off the key cylinder to lock/hnlock but not sure if or where or what retains it in place. Any and all assistance is appreciated. Thanks in advance..
Old Oct 3, 2021 | 06:39 PM
Just Strokin's Avatar
Just Strokin
And it might help if you gave up some info on your truck. Did you buy it used with this lock unknown to you? Are there any wires running out the bottom of the tailgate?
https://vehiclesecurityinnovators.co...gory/pop-lock/
Old Oct 3, 2021 | 07:28 PM
Cliff67's Avatar
Cliff67
5th Gear
Used truck manual tailgate lock.
Old Oct 3, 2021 | 08:55 PM
Just Strokin
You can get the plastics pieces at most part stores in the help section for the Dorman items.....or go to Dorman an look for your items...
www.dormanproduts.com
Old Oct 5, 2021 | 12:51 PM
marksman76's Avatar
marksman76
try this part number F85Z-1521952-BA
Not sure exactly if this is what you need?
Old Oct 5, 2021 | 01:04 PM
Cliff67's Avatar
Cliff67
5th Gear
Fixed
Thanks for trying but was hoping for possible picture of how it was supposed to be from OEM but never found. After tearing apart tailgate to get at latch found that the pivot pin on plastic lock part was broken, replaced with short stove bolt and nylons nut. It works perfect now.
Old Oct 5, 2021 | 01:08 PM
seville009's Avatar
seville009
This guy posted a thread with pictures.....not sure if it helps....
https://www.ford-trucks.com/forums/9...lock-swap.html
Old Oct 5, 2021 | 01:11 PM
Cliff67's Avatar
Cliff67
5th Gear
Perfect
That is exactly what I was hoping to find. Thanks. Figured it out after taking mine completely out and playing with pieces for a few moments.
CMRA 270
Dec 24, 2017 10:42 AM
killer608
Dec 23, 2014 10:24 PM
SasquatchZilla
Nov 25, 2012 08:02 PM
BigNiner19
Oct 26, 2011 11:44 AM
GUNNERDOG
Nov 24, 2009 04:21 PM
