Sponsored by: Real Truck
Upfitter Switches Wiring
Old Sep 13, 2021 | 03:11 AM
SWV10's Avatar
SWV10
My 2016 F350 has the upfitter switches, I was able to pull the wires up enough from under the hood and behind the fuse box. Those 4 wire pigtails under the hood are not the same color as the pigtails for the aux switches, so how do you know what wire connects to the correct color wire for the aux switch? I found 13 pigtails under the dash, none of the 13 pigtail's are the color wire of the Aux Switches and a separate 4 bundle of pigtails of the correct colored wires for the 4 aux switches. 3 of the Aux Switches I can use with ease for dash mounted power items, the 4th (Number 3 Aux switch) I want to use for my Raptor Grill lights which is a violet color wire with light green for the Aux 3 switch.
Is there a wiring diagram that beaks down the 13 pigtails to match to the correct 4 pigtails for the aux switches to be used if you need to do a hookup from under the hood?
Old Sep 13, 2021 | 07:23 AM
Just Strokin's Avatar
Just Strokin
The four wires behind under the hood are feed thru wires only. There is NO connection on either firewall side of those wires. If you look at the cab ide wiring harness that feeds thru the firewall, you will see the same color for the 4 wires you identifies under the hood. The output wires of the upfitter relay box are taped to this same harness that feed through the firewall, but are not connected to anything. They are blunt cut wires.
Old Sep 15, 2021 | 07:29 PM
Tumbleweed1972's Avatar
Tumbleweed1972
I am not sure if I misunderstood but I know on my truck the wires for the upfitter switches were just hanging down in the footwell around the steering shaft. I tested which one went to which switch with a test light and flipping the switches on and off.
Old Sep 15, 2021 | 11:14 PM
SWV10's Avatar
SWV10
Thanks, this is exactly what I needed to know. I hooked up the correct wires and now my raptor lites come on whenever I flip up the Aux 3 upfitter switch.
Desert Don
6.7L Power Stroke Diesel
113
Aug 22, 2018 01:52 PM
Fordboy880
Jun 22, 2018 05:01 PM
tcrane
Nov 9, 2009 06:43 PM
airharley
Aug 21, 2007 01:37 PM
dorkpunch
Jun 9, 2005 11:53 AM
