how do i determine which blunt cut wire to use to connect to one of the aux switches in my 2005 F-250 Lariet? which one is best to use for a strobe light mounted to my backrack.....I have wires ran, but now i am stumped, because there are so many blunt wires behind the dash/steering column..............thanks
The four wires from the upfitter switches should be labeled. They are right under the steering colume. Switches 1 & 2 are 30 amp fused. Switches 3 & 4 are 10 amp fused.
Depending on amp draw for your strobe, pick a switch and wire up to it.
