Ignition Timing Problems
No clue whatsoever why my initial static 12* on the balancer turns into 45* with a light. There has to be a logical explanation.
Maybe carb/fuel or ignition control problem
I would check everything. voltage to the coil. firing order. try a different ECM. try a different light if it's a dial back. try everything whether is seems logical or not because it will probably be something you didn't suspect.
2. So I started retarding the distributor. As it was turned the idle speed fell from around 900 to around 750 at 12*.
3. I increased initial to 14, then 16 and finally 18* to get a nice curve that’s all-in at 3000 RPM with 36*.
4. No clue whatsoever why my initial static 12* on the balancer turns into 45* with a light. There has to be a logical explanation.
You already verified that the weights are not opening at idle, so 45* is incorrect (as you already know).
With regard to point 2, the drop in rpms as the dizzy is retarded is the correct behaviour, but it would not remain at a static 12*. The timing would be retarding !
With regard to point 3, if your initial was 18*, and the total was 36*, that would reflect a curve of 18*. Does two 18L limiters provide an 18* curve ?
Which brings us to point 4, and that sort of problem has been around since post 1.
Is the timing light connected to the HT lead closest to the t/stat, (I.E. HT lead number 1) ? (I assume yes from your comments with dlburch)
Is the connector on that HT lead facing the right way ?
If yes to those questions, then one has to question the accuracy of the actual timing light.
If you can borrow one that is known to be accurate, then borrow it.
If not, buy a new basic cheapish one, which doesn't have to be a dial back, and try it.
As far as I can tell, the only thing you did was remove the dizzy, change a few things, and reinstalled it.
So, assuming you put everything back together correctly, and didn't f$$k anything up, the only valid reason for the 'weird' observations is a faulty timing light.
I hope it's as simple as that !
- I get why idle speed drops, but it doesn’t seem right it will even cold-start at such a high measured initial (45) and so much retarding is needed from the starting point. I don’t understand your reference to static 12* and retarding.
- Good point and on that’s been bothering me. From the little I think I know an 18L limiter should provide 36* total mechanical advance. So if that’s correct I should see all-in at 36* plus initial, in this case another 18, for a total of 54*? High.
-Positively yes
- I didn’t know there is a right or wrong way for the connector to face. Can you elaborate?
If you meant that you started at 45* and ended up at 12*, I understand, but I don't trust the 45* starting point.
LMAO @ ''From the little I think I know ''. ( I can totally relate.
)Yes, I would also expect 54* at idle.
On my basic timing light, in the block shaped section that slides over, and locks to, the HT lead, one of the rectangular surfaces has 'this side must face the plug' moulded into the surface, and that's what I mean by facing the right way.
I'm pleased that you have a second timing light and another engine to use to verify their accuracy.
I’ve never noticed anything on my timing light clamp. Interesting, I will look. And thanks for brainstorming with me.
