Chasing Down Injector Codes
Old Jul 1, 2021 | 11:10 AM
hstechfl's Avatar
hstechfl
On to my next problem- I am getting a p1293, p1294, and p1277 when running the injector buzz test. All the injectors buzz, however they do sound inconsistent. On the driver side cover, I had found bare wires going into the valve cover, so I bought a new pigtail and soldered these in. The passenger harness looked OK so I left it alone. From what I have read, the 1277 relates to injector 7 which is on the passenger side. So far I have done the 50 cent mod, cleaned the valve cover harnesses and the big harness that these connect. The truck seems to run OK but it does seem like a slight miss. It starts up fine and does not smoke. I also ran the contribution test and it shows all OK except for cylinder 8, but from what I have read that it to be expected in many cases. I also notice more noise coming from the driver side which leads me to think its coming from #8 also.
I searched this problem and many have mentioned the IDM itself. Is it possible for all injectors to buzz, but still throw these codes if the IDM is bad?
Old Jul 1, 2021 | 01:29 PM
FinnishStroker's Avatar
FinnishStroker
As long as you have codes,the main problem is electrical.
Tell us more about your injector mileage and condition.
Old Jul 1, 2021 | 02:39 PM
hstechfl's Avatar
hstechfl
The truck is a 2001 with 200k miles. I have opened the valve cover gaskets and it appears that at least 1 of the injectors have been previously replaced. I am sure it would definitely benefit from a new set of injectors, but I just want to make sure there are not electrical issues before considering replacing them..
Old Jul 1, 2021 | 09:56 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the injectors buzz at all the IDM is working. Did you clear the codes after the 50 cent mod?
Not really seeing a need for injectors. It runs fine right?
Old Jul 2, 2021 | 07:49 AM
Listor's Avatar
Listor
I don't have any codes for my injectors, but i did have to replace my o'rings (drinking oil like a sailor on shore leave, and fogging the neighborhood)
also saw one of my injectors had been replaced with an alliant, makes me consider new sticks too
But she runs good for the most part so leave them alone for now
Mdennis0_8
May 4, 2014 08:35 PM
Sharonl12
37
Jul 1, 2013 03:13 PM
fixnair
Feb 20, 2011 08:22 PM
bobert64
Mar 27, 2007 11:14 PM
mudinford
Jul 27, 2004 09:01 PM
