Injector problem
Old Mar 27, 2007 | 11:57 AM
bobert64's Avatar
bobert64
Injector problem
I am working on a 95 powerstroke. It's hard starting and runs rough. I put my otc scanner on it and did a cylinder contribution test. came back with cylinders 1,3,5,7 not contributing. I checked the harness pluse on a scope and I am getting a pulse to all four cylinders. I plan on checking the wiring in the valve cover next. Am I on the right track or am I missing something
Thanks
Robert
Old Mar 27, 2007 | 12:43 PM
tjbeggs's Avatar
tjbeggs
yes you are on the right track. you can check the harness with an ohm meter. That will test the harness and the injector solenoid.
the 5 pins of each connector are set up like this
1 2 3 4 5
1 and 5 are glow plugs, 2 and 4 are the low side to individual injectors and 3 is the high side to both injectors
place your ohm meter between 2 and 3 then 3 and 4. if either test more than 3 ohms you have an issue there. if they test good then thats not you issue. usually when a hole bank goes bad the IDM is shot.
Old Mar 27, 2007 | 08:08 PM
bobert64's Avatar
bobert64
Thanks Tim.
I checked the omhs, they checked out in the 2.5 to 3.2 ohms. I did the injector buzz and came back with all sorts of codes. but I could hear the injectors buzzing. most of the fault codes were related to the right bank but had a couple of issues on the left side. Kind of leaning toward a bad IDM but at a thousand buck I need to be sure. I will check the wiring between the IDM and the injectors tommorow. any advise. thanks
Robert
Old Mar 27, 2007 | 08:39 PM
tjbeggs's Avatar
tjbeggs
if you know anybody with a powerstroke try their idm. also ckeck out this thread for another source for an idm
https://www.ford-trucks.com/forums/5...e-rebuilt.html
Old Mar 27, 2007 | 11:14 PM
bobert64's Avatar
bobert64
Thanks again Tim. will be looking into both options.
Robert
