cruising rpms question
Old May 4, 2021 | 11:43 AM
maf226's Avatar
maf226
2007 E450 box truck with 5R11OW transmission and 6.0 powerstroke will not go into overdrive.I drove to dealer and left for repair estimate.Overdrive is shredded,needs reman Trans for 6800.00. I am feeling that is not right,so I am going to go get it and drive to another shop.
My question is what rpms can I safely drive at down the hiway at sustained speed/rpm to get to the other shop?What is maximum rpm,ram, what sustained rpm for 10 to 15 miles can I travel at?
When I asked the service writer he said not over 5000 rpms.I have a hard time believing that.What is the real answer?Thank you.
Old May 4, 2021 | 03:11 PM
bismic's Avatar
bismic
I would think 4000 rpm would be the max, with 3800 being the upper target.
Old May 4, 2021 | 06:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The engine will not run at a speed that is dangerous for the engine. The PCM limits engine speed. If you can get the engine to run at a certain speed, it is safe to do it.'
Does the trans have all other gears? Does it shift 1-2-3-4? Because second gear uses the same overdrive clutch as overdrive gear.
Old May 4, 2021 | 06:44 PM
bismic's Avatar
bismic
"Defuel at 4000 rpm's to limit damage to the powertrain" Source : Ford PC/ED manual - page 1-13
I have been told by a Tech that he was taught by Ford Technical that damage can occur at over 4200 rpm (assuming the F450 would be the same as my 2006, and I don't see why it wouldn't be).
Personally I wouldn't risk getting all that close to that rpm.
uppernorth
2009 - 2014 F150
Feb 16, 2017 10:25 AM
XxWINxX94
Jun 29, 2011 08:22 AM
duallyking
Feb 15, 2008 11:34 AM
BCBen
Apr 16, 2004 07:40 AM
