Quick Noob Question on Speed
Old Jun 27, 2011 | 08:51 AM
XxWINxX94's Avatar
XxWINxX94
Hello everyone,
Just recently got my dent and I'm younger and somewhat new to the older-vehicle scene.
My truck is a '78 Short Box 4x4, 4 speed. 351m 400 engine with T18 trans.
No problems at all with driving around town or anything but I will be taking a longer distance vacation soon requiring interstate travel and have a question.
When I put it into 4th gear, it sounds good up until around 60. I don't have a tac, but RPMS are really high and it sometimes makes me nervous.
Speedo goes up to 85 but I've never had it up that high.
I guess my question is; Is it normal for the dents to get really loud/lots of RPMS at higher speeds?
If this is a stupid question, I apologize. I guess I'm used to the newer cars where you can barely hear the outside when driving 60+.
Also, is it OK to maintain those speeds even with the high RPMS and loudness?
Old Jun 27, 2011 | 09:10 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Engine is naturally going to rev higher than newer vehicles. You have a 1:1 final drive where just about everything now has overdrive. Gear ratio in differential will contribute to that. Lower the gears, higher the rpms. Tire size can play a factor also. It would not be abnormal for it to be turning 3000 rpm at interstate speeds where a new vehicle might be running 1800-2000 rpm. These vehicles were made when speed limits were 55mph and designed for that.
Old Jun 27, 2011 | 10:02 AM
devino246's Avatar
devino246
^Yep. My engine sings at 50, it screams at highway speeds. Fastest Ive gone is about 73.
Old Jun 27, 2011 | 11:05 AM
'78F250351m's Avatar
'78F250351m
Yea don't expect to go much over 60mph without the rpms bein high.
Old Jun 27, 2011 | 11:13 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Running 3k rpms while annoying, won't hurt the engine. MPG however will suffer.
Old Jun 27, 2011 | 01:10 PM
HIO Silver's Avatar
HIO Silver
"Loud" is relative. ...About the only insulation these rigs have is the cardboard used for the headliner, a firewall pad, and a rubber floor liner or carpet.. Sound deadening (and evidently rustproofing) for working trucks was only a concept back in the day!!!
But hey, we've got the survivors so keep'em on the road. Congrats on your new-to-you 4x4 and welcome to the Dentside brethren.
Old Jun 27, 2011 | 02:54 PM
finneys98xj's Avatar
finneys98xj
My 78 long bed 4x4 400 with a np435, 3.50 gears Doesn't sound loud only sound normal.
Old Jun 28, 2011 | 12:51 PM
XxWINxX94's Avatar
XxWINxX94
It does have bigger tires but I understand these weren't build for speed I will just cruise at 60-65.
Old Jun 28, 2011 | 11:57 PM
76f350spercamprspeal's Avatar
Maybe it's in 4x4 mode?
Although the truck should be loud, it shouldn't be that loud or revving at that high of a RPM (I would think)
Old Jun 29, 2011 | 12:54 AM
SuperDuty93's Avatar
SuperDuty93
Did you look to see if it has headers? My truck 1974 F250 screams at 70!
My 79 bronco is loud but you can hear the radio over it very easily without turning it up high.
Old Jun 29, 2011 | 06:30 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is one of the best calculators I've come across. Drop down menu's for tranny's, transfer case and ability to compare any changes you might think about side by side. A cheap SunPro tach and you can keep your engine in it's powerband for best mileage.
Gear Ratio Calculator
Old Jun 29, 2011 | 08:22 AM
bigdaddys76's Avatar
bigdaddys76
keep this in mind though, the higher the RPM's the faster you are gonna beat the viscosity out of your oil. So if you do intend to do a lot of high speed interstate running and this truck is geared low you will be doing more oil changes.
I'm not familiar with the T-18 and can only assume that it is a "granny four speed" so its not like its a four speed being fourth is an overdrive so with that your fourth/final gear is like normal drive and highway speeds are gonna sound like you are tached up real high. But again I dont know if a T-18 is a granny or not.
Look into a taller tire, if and when you need tires, and you will drop some RPMs
Xecular
Jul 15, 2016 11:48 AM
GM4WALLS
13
Jun 21, 2015 12:03 PM
ayden2004
2004 - 2008 F150
Feb 28, 2015 03:48 PM
crazyuncle
1983 - 2012 Ranger & B-Series
May 7, 2014 05:49 PM
littledre1
19
Sep 11, 2007 08:52 PM
