trans question
Old Jan 28, 2017 | 11:54 AM
uppernorth's Avatar
uppernorth
trans question
One of my customers has a 2011 f150 5.0 . He says that in the last 4 months while driving at 60 the rpms will jump from around 1500 to 3000 then go back to normal . What would cause this ?
Old Jan 28, 2017 | 12:26 PM
uppernorth's Avatar
uppernorth
should of been last 2 months instead of 4
Old Jan 28, 2017 | 01:04 PM
640 CI Aluminum FORD's Avatar
Hard to say. But with this little bit of information given it sounds like for some reason the truck is downshifting from 6th to 4th gear. You'll need to provide more detailed information pertaining to the issue for a better answer.
Old Jan 28, 2017 | 01:31 PM
uppernorth's Avatar
uppernorth
He says it doesn't downshift said it just goes up to 3000 for a few seconds then back down . No surge at says its like idle
Old Jan 28, 2017 | 03:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's impossible to say without checking for codes. And the places that read codes free CANNOT read these codes. You need either a good independent shop or a Ford dealer.
Old Jan 29, 2017 | 05:59 AM
fastback89's Avatar
fastback89
Has anyone checked the fluid level? I have seen several of these leaking at the bulkhead connector, sometimes it's can be a slow leak. maybe it's a few quarts low?
Old Feb 1, 2017 | 07:18 PM
johnday's Avatar
johnday
Does he have a tuner on it?
Old Feb 2, 2017 | 09:24 AM
uppernorth's Avatar
uppernorth
No tuner on it
Old Feb 16, 2017 | 07:57 AM
johnday's Avatar
johnday
No tuner on it
Sorry about not keeping up on this.
I asked about a tuner, because mine on the 93 Race MPT tune, it does something similar. It doesn't grab that many rpm, right around 500, on cruise, in drive, while going up slight grades. No downshift, but seems like the torque converter is unlocking, then locking back up. Sometimes it even jerks.
Now with my 5* tunes, this doesn't happen.
I know it sounds like my tune is causing it, but I would like to hear what the outcome is on a stock tune. Might be something to keep in mind.
Old Feb 16, 2017 | 10:25 AM
WXboy's Avatar
WXboy
I'd verify that the fluid level is correct.
If so, I'd check the bulkhead connector for the common leak.
If it's dry, then you've got either a contaminated "molded lead frame" inside the transmission, or a plugged up filter. There was a TSB on the molded lead frames in those model years...some people even had the trans. shift to 1st gear at interstate speeds on them. Talk about scary!
Kijutsu
2015 - 2020 F150
Nov 10, 2018 06:24 PM
Tylus
Sep 23, 2012 05:51 PM
duallyking
Feb 15, 2008 11:34 AM
mercman64
Oct 19, 2006 09:51 PM
k-rider
Aug 16, 2003 09:42 PM
