transmission question
Old Feb 15, 2008 | 08:08 AM
duallyking's Avatar
duallyking
I have an 07 truck with the 6.0. I am wondering if this is normal, or should I bring this up to the dealer. The truck isn't pulling or carrying any load. When going up a hill, I will maintain the same rpm. The transmission sounds like it is lugging. If I give it some "gas" the trans will drop a gear. Is this lugging noise normal, or a sign of the trans slipping, while it is in overdrive?
Old Feb 15, 2008 | 10:08 AM
slowmans's Avatar
slowmans
what rpm are you at before it kicks down, I know mine will sometimes be around 1200 before it kicks down...
Old Feb 15, 2008 | 10:13 AM
duallyking's Avatar
duallyking
I was driving around 40mph on the street. I recall my rpm was about 1200-1300 range when it has that lugging noise going up a hill.
Old Feb 15, 2008 | 11:07 AM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Sounds like the sound mine makes under similar circumstances. I consider it normal.
Old Feb 15, 2008 | 11:34 AM
69cj's Avatar
69cj
Sounds normal to me. The trans will upshift with no load and then as it loads up will downshift with the decrease in rpm.
