F550 towing build thread
Old May 15, 2021 | 05:54 PM
  #61
SkySkiJason's Avatar
SkySkiJason
The red could be Redkote tank lining. I tried that too. Not cheap. Hot acid bath, then apply the product and slowly rotate tank to get it everywhere. It failed too.
Do the in-tank and pre-pump mods. I do this for $20 in parts you can probably get 100% locally.
If the WIX 33972 has a short service life, get the RACOR PS120.
Replace tank is best option.
Old May 15, 2021 | 07:47 PM
  #62
Hvyhaulr's Avatar
Hvyhaulr
Thanks, I will probably order a new tank this weekend.
Old May 15, 2021 | 08:11 PM
  #63
SkySkiJason
I’ve seen the axle tubes crack near the perches before. See if you can find the damage after cleaning it up.
Old May 15, 2021 | 08:23 PM
  #64
RacinJasonWV's Avatar
RacinJasonWV
The screen housing looks dark. How were the screens? Any photos? Just curious.
Old May 15, 2021 | 09:25 PM
  #65
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Hvyhaulr
I noticed it was wet around the perches....
Everything was intact, I was suprised at how little they welded the perches from the factory though.
I have the bigger Dana S135 and I have seen it at a max GAWR of 16,500 lbs in bigger trucks. I think they de rate it on the F550 to 15k or 15,500 lbs due to tires and wheels. I was overweight on tires but bumped up to a higher rating. I probably should do wheel bearings since the axle has almost 400k on it.
Originally Posted by Y2KW57
The Dana S135 is rated for 13,500 lbs,
Ford did have a 15,500 lb GAWR axle, but that axle was a Dana S150. (not available in an F-550)
The major distinction is in material thickness of the housing...the housing is thicker on the S150, and that is a key determining factor in the axle's rating capacity.
(some) managed to crack the housing to the S135, right at the spring perches.
The oil wetness surrounding the spring perches is the same indicator, symptom, and manifestation of the cracked S135 axles found on F-550's with aerial lifts (bucket trucks).
For your axle oil fill level to be as low as it was, and for there still to be as much oil as there is surrounding your spring perch, suggests that there is a crack in that axle housing, right where cracks typically occur in that particular axle housing, when the axle is overloaded.
The S135 axle housing is 7 mm thick.
The S150 axle housing is 8 mm thick.
The S135 housing material is HSLA (high strength low alloy), which is where some strength in lieu of additional unsprung weight is recovered, but the axle is rated at 13,500 lbs, not 15,500 lbs.
It's good that you caught it at home, rather than out in the middle of the desert.
Old May 15, 2021 | 09:36 PM
  #66
Bently_Coop's Avatar
Bently_Coop
..........It's good that you caught it at home, rather than out in the middle of the desert.
Imagine if you killed a bus full of Nun's.
Pretty sure they use to say that on Pirate about FTE.
Old May 15, 2021 | 10:05 PM
  #67
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The subtext underneath the quote above is lost on me, but the advantage of discovering a crack at home rather than in the desert is that it there is a better chance to successfully repair the crack before it propagates into an unrepairable partial separation, deforming the housing. The housing always has been very costly, and with that axle being out of production for 16 years, a replacement housing is more difficult and expensive to find than a replacement truck.
But a "crack" (haha) welder can fix it. And if the welder knows the procedures for pre heat and post weld heat on HSLA material, the repair will likely last until the truck meets it's maker in the clouds, surrounded by nuns.
Old May 15, 2021 | 10:39 PM
  #68
Hvyhaulr's Avatar
Hvyhaulr
with the amount of crap on the axle tubes in that area something tells me this has been cracked for a while. I had to chisel off multiple inches deep of grease and fluid and all sorts of road debris. This truck very well could have been overloaded for years and cracked for a while.
time to figure out the next step!
Old May 16, 2021 | 02:46 AM
  #69
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Nice progress, fun to watch!
A good weld on any cracks will put it right. Clean it up to find the cracks. Unless you are really good at welding I'd hire the best pro you can find. A bad weld will just crack again, deeper, since the heat treatment of the steel will be compromised.
Old May 16, 2021 | 07:48 AM
  #70
SkySkiJason
High strength/low carbon steel has very specific welding procedures as Y2K eluded to. Not following these WILL result in failure.
Here’s some heavy reading on the subject.
https://www.twi-global.com/technical...sla-steels-098
I worked with boilermakers and pipe fitters most of my life. I often tell people I know the difference between a welder and a welding machine and that I have a welding machine (or 3) at home and sometimes a welder shows up.
Old May 16, 2021 | 08:37 AM
  #71
RA101725's Avatar
RA101725
Banned
Interesting factoids there but it looks like that's been that way a long time from all the seepage and grime. I assume the right way to correct that is take the axle out and let a drivetrain shop fix the cracks. Either that or find a good used one but I would prefer to fix the original one were it me. (Or if he wanted to get mod crazy, find an S150)
Old May 16, 2021 | 08:44 AM
  #72
RA101725's Avatar
RA101725
Banned
What did the little screens in the sending unit look like? You can probably just re-use that tank if you do the hutch mod to eliminate that and add the PS120 deal mounted to the frame rail, so you can see if crud is building up in there. Theoretically only so much tank lining can delaminate and end up in the filter before the problem corrects itself right? (lol)
Good thing you caught that drain plug. If that thing fell out you'd have heard about it pretty quickly.
Old May 16, 2021 | 08:56 AM
  #73
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Brandonpdx
I would prefer to fix the original one were it me. Or if he wanted to get mod crazy, find an S150
There was no S150 made for an F-550.
The amount of welding required to rework any given S150 housing to match the spring perches, shock absorber mounts, anti sway bar brackets, and pinion angle would be a significantly more substantial effort than repairing the existing axle.
Old May 16, 2021 | 09:08 AM
  #74
SkySkiJason
We can still find good complete axles for less than it costs to rebuild one. Just bought the axles from the red truck to do a 4wd swap on the black truck. Obviously, condition matters - but the 160k miles axles are likely better than the 300k mile unit.
Old May 16, 2021 | 09:23 AM
  #75
brokestroke's Avatar
brokestroke
If it were me I would clean it up good, v-groove the housing and lay 3-4 passes with a good cap weld. I wouldn't even disassemble anything as it looks on the inner side of the perch weld. In my experience those stamped housings weld easy.
