How to make perdels work ?
https://www.ford-trucks.com/forums/1...-possible.html
SSJ mentioned in post #21 that he was not able to read PERDELS on some trucks he worked on, but not sure what the cause was.
I will end up putting injectors in regardless
but for now i will work on other things that need attention: Broken airbox, time to replace
Riffraff Diesel 6637 Filter Kit RDP6637-RED 1
6637 Replacement Cover - Red RDPCVR-RED 1
Cam Position Sensor CPS 94-03 F4TZ12K073C 1 just cause i don't have a spare!
Have you noticed any similarities between your truck and the others in the "no PERDEL for you" section.
Year, PCM calibration, GPCM, remanufactured electronics, anything?
There must be a common aspect among them. Maybe that specific aspect doesn't have the PERDEL PID access like BARO being exterior to the PCM in E99 or ECT not being applicable except in 2001+ ZF6 trucks.
Thoughts?
Thoughts?
