New Purchase - 7.3 Excursion Build
Old May 29, 2021 | 08:10 PM
  #61
BWST's Avatar
BWST
Got Data?
They are! Had to do that on my rig not too long ago. The flopping around is probably due to a worn out knuckle seal. Recommend doing the seals at minimum, and see if the needle bearing needs it too. On my truck, both sides had movement in the u-joints and needed seals, but only one side required a new needle bearing. Details in my maintenance thread below. Parts I used listed in Post #1
https://www.ford-trucks.com/forums/1...l#post19275506
might have to skim past several non-relevant posts - I was doing several repairs at once.
Old May 29, 2021 | 08:54 PM
  #62
dclack's Avatar
dclack
Sweet! For that price I might as well just replace both bearings and seals.
Old Sep 19, 2021 | 06:47 PM
  #63
dclack's Avatar
dclack
Anybody have the service manual or how to diagnose the ESOF? I know the 4wd worked before the trans swap but not now. I verified that I plugged everything back in and that the fuse under the dash is good. The only other noticeable symptom is that the 4x4 and 4lo lights don't prove out when you turn the key on.
Old Sep 19, 2021 | 07:02 PM
  #64
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
In the 7.3L PSD Tech Folder there are a couple of ESOF pinpoint tests based on the MY.
Axles & Hubs
If that doesn't get you what you need/want, you can request a copy of the Ford Service Manual for free at the link below.
https://www.ford-trucks.com/forums/1...highlight=ford
Keep us updated!
Old Sep 19, 2021 | 09:22 PM
  #65
dclack's Avatar
dclack
Thanks. That will be helpful. I did find out that the dash lights do prove out, but after the engine is started not on initial key on like the others.
Old Oct 2, 2021 | 10:15 AM
  #66
dclack's Avatar
dclack
Still haven't figured this out. All fuses, relays, and power sources to the control box are good. The relays do not click when I turn the switch; so guess that's the next thing to check.
Old Nov 5, 2021 | 07:17 PM
  #67
dclack's Avatar
dclack
This 4x4 issue is starting to tick me off. Everything worked just fine before the transmission swap, but now nothing. I've checked the relays, dash switch and several circuits while trying to follow the service manuals; everything checks out good but still nothing.
Old Nov 5, 2021 | 07:41 PM
  #68
dclack's Avatar
dclack
Nevermind! I'm just an idiot! When I first noticed the 4x4 wasn't working I checked the two connections at the t-case thinking I didn't get them connected. Well they looked fine, so I moved on to the next check. I just went back to check the plugs for corrosion and sure enough I didn't have the upper plug all the way in. Everything works now.
Old Nov 5, 2021 | 08:21 PM
  #69
BBslider001's Avatar
BBslider001
So great when it's the simple things
Old Nov 5, 2021 | 08:27 PM
  #70
Sous's Avatar
Sous
FTE Emeritus
Outstanding news! I had a similar issue when the "locking" connector on the transfer case motor was not "locked" and came out about 1/8".
Easy day!
Old Jun 16, 2024 | 01:00 PM
  #71
dclack's Avatar
dclack
Hmm, looks like it's been a few years since updating this thread. Unfortunately I'm not here with good news. I just found oil in my coolant. My first thought was injector cups but I guess it could also be the oil cooler. Any way to narrow it down?
Old Jun 16, 2024 | 01:49 PM
  #72
Tpayne621's Avatar
Tpayne621
Looks like mine when it was oil cooler.
Old Jun 17, 2024 | 09:35 PM
  #73
T-wood's Avatar
T-wood
It’s not a bad job to reseal the oil cooler. Remove all of the oil cooler. Don’t take the shortcut seen in some videos. One of the guys here didn’t remove the front part of the cooler and broke his front cover during reassembly. Check the sticky for coolant flush too.
Old Jun 17, 2024 | 10:38 PM
  #74
dclack's Avatar
dclack
I've done the oil cooler on my '97. I just hope it is the cooler and not the injector cups. My wife really needs this rig for a trip next week. So I don't have the time for that fix if it's not the cooler. I've ordered both the seal kit and a new cooler.
Old Jun 18, 2024 | 09:48 AM
  #75
Tpayne621's Avatar
Tpayne621
Cups are generally diesel in coolant.
