Cam question
Old Mar 31, 2021 | 05:31 PM
  #46
wwhite's Avatar
wwhite
Originally Posted by Tony ray
The Pimp x looks interesting, Question though would you need to get a dyno tune to dial it in or does it do it itself. And does it work with SD or does it take over the the whole system?
You do not need a Dyno tune, you as the tuner would tune it as you drive it.
I think when you order it, you specify SD, and then you have different options like batch fire vs sequential fire. PimpX can be configured to whatever you have and whatever you want.
I also think that the Pimpx uses its own MAP sensor, its inside the ECU, then you have to plumb the vacuum tube.
Old Mar 31, 2021 | 06:21 PM
  #47
Zrt1200's Avatar
Zrt1200
Look at this thread on the PimpXshift. Grab a few brews and watch some videos of it. If you have a stickshift you dont need the Xshift. Also use your search on here for PimpXshift as there is a few threads.
https://www.ford-trucks.com/forums/1...nd-review.html
https://www.stinger-performance.com/...ine-management
And Stinger has a very good message help board as well. You wont be able to see and graphs or tunes on there forum without a license but you can read a lot about the system and what questions people come up with.
​​​​​​https://stinger-performance.proboards.com/
Old Mar 31, 2021 | 07:47 PM
  #48
Tony ray's Avatar
Tony ray
Thanks ZRT1200, lots of thinking and research to do, Also the PO rebuilt the engine last year but all the EFI is original.
Should any of the EFI need updating as its 31 yrs old now. It runs well with your foot into it but around town it with light touch on the throttle it sort of stutters.
Old Mar 31, 2021 | 07:49 PM
  #49
EllieMae94's Avatar
EllieMae94
And in addition to the link Zrt1200 linked of my review, check out this one by Mikulh. He did a great write up:
https://www.ford-trucks.com/forums/1...x-install.html
Shwan_89HD
18
Apr 14, 2012 05:34 PM
Ford_Six
Feb 23, 2010 04:49 PM
smallblock351w
Mar 6, 2007 09:47 AM
thecowboy
Oct 20, 2004 07:37 AM
f100guy
13
Sep 14, 2003 01:04 PM
