cam recomendations
Old Sep 10, 2003 | 09:39 PM
f100guy's Avatar
f100guy
cam recomendations
i built a 302 with .060 coated hypereutectic speedpro pistons redone heads weiend intake and 600 cfm carb. i also have a melling cam 280 duration and 474 exhaust lift it lopes pretty good and does not burn the tires but that is funny because the old worn out stock engine burned the tires. i talked to an experienced ford engine builder and he thinks it is some sort of rv cam. it has fairly good takeoff but it is getting the power at a higher rpm than i want it to. i did not degree the cam yet but maybe when i do it will straighten up.anyway can anybody find a good low end torque camand post the link here saying that this is my first engine build and i know nothing about cams. thanks
Old Sep 11, 2003 | 12:47 AM
DW2455's Avatar
DW2455
cam recomendations
My friend i've told you the cam spec you list are a good choice, but there is one other possibility other than a problem with your motor, and that just maybe your cam was mis labled and you got the wrong one, but any way give these people a call, give them your info and go wiyh what they tell you,
1-800-999-0853. Good Luck DW
www.compcams.com
Old Sep 11, 2003 | 07:06 AM
StrangeRanger's Avatar
StrangeRanger
cam recomendations
280° advertised duration is going to be a high RPM cam. If you want low range power, you need something in the 264-268 range
Old Sep 11, 2003 | 11:00 AM
jwtaylor's Avatar
jwtaylor
cam recomendations
I think in your last thread I made that comment and for some reason at the end of the thread had it in my head you had a rv cam. As mentioned before I agree with strangeranger it is designed for use up there in the rpms and your gonna need gears + high stall to make it work right, or a new cam. If you are on a budget I would say cam and besides it would make your truck operate better all together, your looking for off idle grunt. If we were talking a built BB then maybe you could get away with it, but if I recall you have a mild 351, correct and you probably won't create enough torque to be happy with it? good luck
Old Sep 11, 2003 | 05:11 PM
f100guy's Avatar
f100guy
cam recomendations
302
Old Sep 12, 2003 | 03:00 PM
Justme's Avatar
Justme
cam recomendations
I dont have that much experience with Ford engines yet I believe I remember someone telling me the 302's are restrictive in the exhaust side of the cylinder head: yes/no?
If this is true would you also not want a dual pattern cam?
As for the 280 cam: if you have not altered your Static Compression Ratio to match the needs of that 280 duration and are using factory stock pistons (low comrpession) then you are asking for trouble.
If this is a daily driver-you really need a cam in the 260 duration range...as mentioned in a previous post. The 280 cam will place your peak hp up in the 6500 rpm range. If your engine never sees the other side of 5000 rpm's then you have mismatched your components with the intention of your vehicle.
As a result your torque at low rpms, with your 280 cam, will be severly compromised.
Kevin,
Old Sep 12, 2003 | 04:54 PM
f100guy's Avatar
f100guy
cam recomendations
.060 block, redone heads, hypereutectic coated pistons with valve reliefs that 280 cam .010 under crank wieiend intake 1406 600 cfm carb. i don't know the compression ratio the heads were shaved. just a mild street 302. i did not know anything about cams i just told them something that loped a little i did not know it does this though. i just want something that will be good in an 80 f100 swb, a mustang 2 or a 91 tbird. i want it to have good take off and the power to leave half of my tires on the pavement when i want to show off.i will have headers soon though. i am wanting to get 3.50 gears also
Old Sep 13, 2003 | 10:35 AM
StrangeRanger
cam recomendations
There's easily 1000# difference in weight between an MII and a T-Bird. The cam that works in one will not work well in the other. The difference in tire size between the cars and the truck also affect which cam you choose and which gears will work with it.
Is this engine now in your truck? With 29-30" tires and 3.50 gears that cam would be an absolute stone unless you're running an automatic with a very high stall speed converter. Even then you'd never get into the working RPM range of the cam on the street.
All this stuff has to work together, you can't just throw random parts at it and think it will be quick.
Old Sep 13, 2003 | 11:02 AM
DW2455's Avatar
DW2455
cam recomendations
PLEASE PLEASE PLEASE, PREACH THE GOSPLE!
Tell them while i listen, I dont know why its so hard for people to under stand why they have this big ROMPIDY ROMPIDY motor, and the guy down the street's motor just SCREAMS and he dont have much in it! you cant build a motor to go from a 4700lb. to a 3600lb. to a 2600lb. vehicle, and it perform well in each. DW
Old Sep 13, 2003 | 11:59 AM
f100guy's Avatar
f100guy
cam recomendations
right now it is in an extended cab f150 just to have something to drive while i get the mustangs title fixed or buy the tbird. or i could pick up the 80 model truck but don't think i will. the truck it is in now is totally stock with a 9 inch rear end i think it is a 3.00 ratio with stock tires (little 15 inch pizza cutters), and a c6. i want a c4 but all i got is a c5 which is about the same ,c6,fmx,aod and a 4 speed in the mustang. maybe i could convert it to oa roller cam that would be good.
Old Sep 13, 2003 | 12:29 PM
DW2455's Avatar
DW2455
cam recomendations
Listen if you want this thing to run like it should, (the most bang for your $$$) then you need to forget about the cam untill for make up your mind what you want to do with motor, or build you motor put a stock cam in it and just drive it till you put the motor in the vehicles you plan to leave it in, and then change the cam. IF we sit here and tell you what to put in the motor, then you go put it in something else and it dont perform right, then you'll be walking round tellin your friends (DONT LISTEN TO THEM IDIOTS AT FTE MY MOTOR RUNS LIKE SH..!) you can build it (general pourpose) or (application specific) DW
Old Sep 13, 2003 | 12:43 PM
jwtaylor's Avatar
jwtaylor
cam recomendations
This is entertaining.
Old Sep 14, 2003 | 12:14 PM
tess100's Avatar
tess100
cam recomendations
i have a 2000 lb buggy 4x4 351m motor 35 in mud tires need performance tips i have allready installed holley 4 brl carb and edelbrock intake . i have 1973 351 clevland heads but dont know if they will work what cam do i want . also thinking nitrus .drive train is 1980 f250 thanks in advance
Old Sep 14, 2003 | 01:04 PM
DW2455's Avatar
DW2455
cam recomendations
tess100: are you running 4bbl or 2bbl heads? DW
