Cam question
I was thinking today and wondering if maybe a reason for the factory cams having a wide lobe sep in many of these engines is simply to allow them to be put into the engine with the intake closing way back. I don't know exactly where they had the cam but let's just say the cam was on 114 sep and in on 120. That would reduce low speed cylinder pressure and N2O emissions.
https://www.corral.net/threads/does-...-cams.1176008/
Any EEC-IV computer can be tuned. All lightning EEC-IVs were SpeedDensity(SD), and probably had a hardware code of EFI-SD48.
Lighting computers had C3P1, C3P2 software/calibration/strategy codes and the hardware was EFI-SD48.
Any EFI-SD4x computer can use any other EFI-SD4x software/calibration/strategy, since the hardware is identical.
Any EFI-SD computer can be tuned with a J3 port tuner, Tweecer, Quarter Horse, etc.
PimpX works with both SD and MAF. It is not plug and play as we know it. I am pretty sure you have to re-pin some wires, depending on setup.
Could you elaborate on this EFI-SD4x
https://www.nloc.net/vbforum/showthr...-a-302-H-O-cam
And Post #16 here....
Ford Lightning Cam Specs
For larger injectors, you have to add/modify the injector data. As an example, if you adding 24lb cobra injectors, you need to do modify the following:
Bosch - 24lb #0280150947 / 0280150913 K-Constant 30.00 High Slope 24.839 Breakpoint 0.00001001 Low Slope 24.839
VOLTAGE OFFSET voltage ms 16.00 0.50 15.00 0.50 14.00 0.50 13.00 0.59 12.00 0.81 11.00 0.91 10.00 1.31 9.00 1.51 8.00 2.00 7.00 3.00 6.00 5.00 0.00 7.00
The lightning trucks have software/strategy/calibration/catch code - C3P1 as an example, is a lighting truck 351w E4OD, GT40 heads, tubular intake.
The lightning tunes are different, different shift strategy(firmer), different air flow requirements, and different ignition timing strategy....many more changes as well, fuel map, etc, etc.
Basically, as far as I know, all Speed Density (SD) computers for V8 trucks have hardware EFI-SDxx, early ones were EFI-SD2x, later ones being EFI-SD4x.
I have a 6cyl EFI-SD47A, that I run 351w tune on, using QuarterHorse. Just had to change engine size, number of cylinders, ...tune it.
All EFI-SD4x computers are plug'n'play, it is the same hardware, just different software. There are no wires to re-pin, if keeping Speed Density.
So, any EFI-SD computer hardware can be tuned, and can work.( with supported definition file)
C3P1- Hardware code EFI-SD48B
KID2 - Hardware code EFI-SD48B
Post your 4 digit code, and I'll tell you how well supported or not it is, and if a definition file already exists.
I put the stock lightning tune on my stock 351w(non-lightning) computer.
My trucks computer has software/strategy/calibration/catch code - KID2, that is KID revision 2. Is a 351w E4OD, with E7 heads, stock truck intake.
PimpX price point is the same as Edelbrock ProFlo, and a little more money could get Holley Sniper.
I'm sure there are more systems that are similar in price with support models built in.
Pimpx: $1,350
Holley HP: $1,370
Edelbrock Pro Flo, scratch that, it is for traditional carb to efi.
MegaSquit3: $500- $1,230 depending on DIY or completely built.
There are more, just showing the options.
PimpX is just MegaSquirt3 in a Ford ECU box, that is what makes it plug'n'play, connects to current EEC in Fords.
Here is a quote from PimpX about the plug'n'play and auto learn feature:
Don't mistake that with "plug it in and it just tunes itself" though as there are certainly more steps to it than that, and there is more to the tune than just the fuel table (though the base tune gets most of the other stuff done for you).
Anything is doable, easy by some, might not be easier by others. I found it easiest to tune my stock EEC-IV without another computer, and deal with what I already got.
If I had $5000 to spare on a cam and ECU, I might look at some other option, like ProEFI or Haltech.
