Cam question
Old Mar 21, 2021 | 11:37 PM
Tony ray's Avatar
Tony ray
Cam question
I have a 1990 f150 351w which I bought 6 months ago. The PO rebuilt the engine and kept it pretty stock. It was bored 20 thou and he put KB flat top pistons in which I believe have 12cc valve reliefs. My question is his choice of Cam and I know not much about cam choices.
The cams specs I believe to be-- 194-204 @50 270 - 280. .424. to .448. lobe sep 109 119.
The engine pulls well to 4500 rpm then its no point pushing any harder. I would like it to pull hard all the way to 5500 if thats possible?
Old Mar 22, 2021 | 06:08 AM
DaveMcLain's Avatar
DaveMcLain
That cam has very short duration and it works great in a low compression, low rpm 302. In the 351 it's too small to go to a 5000rpm power peak. I'd do something like 205-205 on a 108 that would get you there and still idle very smoothly.
Old Mar 22, 2021 | 11:54 AM
Conanski's Avatar
Conanski
The stock heads and intake are the bottlenecks on this motor, not that cam.
Old Mar 22, 2021 | 12:00 PM
DaveMcLain's Avatar
DaveMcLain
With less that 200@ .050 duration the cam is keeping the rpm below 5000 not the heads or intake manifold.
Old Mar 22, 2021 | 08:45 PM
Conanski's Avatar
Conanski
No 0.050" duration simply determines emissions and vacuum/idle quality, with 270/280 deg total duration this cam is not restrictive but on this displacement the stock heads and intake are a proven bottleneck. I've put bigger cams in stock 5.8's and got the same results... peak HP occurs at 4500rpm, you can rev it more if you like but it doesn't make more power.. just noise.
Old Mar 22, 2021 | 08:53 PM
DaveMcLain's Avatar
DaveMcLain
Give it a rest 190/202 duration is about the same or even slightly less duration than a stock cam. I'm very aware of the limitations of the factory Windsor heads and I've run 351W based engines with them on my dyno lots of times and they didn't all HP peak at 4500rpm. Why? Because they had more duration than this cam. .050 durations are used to compare cams mainly due to the fact that by that lift the cam is above any clearance or constant velocity ramps in a consistent way. And it also puts the valve at a high enough lift that significant flow is occurring. Seat timing is mostly meaningless since you never know what lift was used to generate the numbers. Was it .006? .010 or .020? Was it the lash point if it was a solid lifter design?
If this engine had a cam with more duration the engine would peak at a higher RPM than 4500. The heads are not that restrictive at this displacement.
Old Mar 22, 2021 | 09:11 PM
Tony ray's Avatar
Tony ray
Thanks fellas, now im more confused I am curious to why the PO picked this cam for the rebuild. I asked about it when I bought the truck and he said it was for low down torque.
Old Mar 22, 2021 | 10:07 PM
Conanski's Avatar
Conanski
It was probably chosen to be compatible with the factory EFI system as much as anything, it is similar to the OEM grinds used in these motors so it was a safe bet.
Old Mar 23, 2021 | 08:54 AM
DaveMcLain's Avatar
DaveMcLain
That cam can run really well in a low RPM engine. I have one in the 302 that I built 30 years ago for my '65 Galaxie. That engine runs great for such a big car with only 302 cubic inches and an automatic. It is pretty similar to a lot of OEM cams but the lobe separation is tighter than what they usually use.
A couple of years ago I did a 393 Windsor for a customer with a street rod. It was a simple build using a stock rebuilder 302 piston, stock heads etc. With headers, an Edelbrock intake and a 600cfm carburetor it was good for 354 horsepower at 5100rpm and 436 lbs/ft torque at 3400. It runs good in a '49 Ford. In that engine I used 218 @ .050 ground on a 106 lobe sep.
The 393 was making more than 345 horsepower from 4400 to 5500rpm so it didn't "brick wall" or fall off very much in the band that I was testing.
Old Mar 23, 2021 | 11:35 PM
Conanski's Avatar
Conanski
That is a nice combo but exactly what head was used, the E7TE head used from '87 on only flows 155cfm on the intake, barely over 100cfm on the exhaust. That is what the OP has to work with.
The early C9/D0 351 heads and the late model GT40 heads have bigger valves and flow close to 200cfm untouched, that starts to get into the range needed to make around 350 hp.
Old Mar 24, 2021 | 01:16 AM
Tony ray's Avatar
Tony ray
Could I get a better cam , if I change the heads should I go with something to match the heads or could I just leave it ?
the engine is only 3000 miles old.
Old Mar 24, 2021 | 08:47 AM
DaveMcLain's Avatar
DaveMcLain
I just worked with what the customer had for parts and he had a 351Windsor core from the early '90's(non roller cam). The block was good with a .030 overbore, the crank was junk so building the 393 made sense and it was easy to build using cheap parts. It was for a street rod so all out performance wasn't really a goal. Given the restrictive nature of the heads and pretty low compression ratio I tightened up on the lobe separation which helped the engine work well. He's happy. It'll really burn the tires and accelerate through the gears. The owner says that it actually feels pretty fast.
That example being a 393 with 40+ cubes should have an RPM range that's close to 800rpm lower than a 351 with the same stuff. I checked my notes and you're right on with your flow numbers. I've tested a GT40 head and it flowed 198 @ .500 lift. In my computer I don't have an E7 but I do have an E6 with the closed in high swirl chamber and it flowed 152 at .600 lift.
Old Mar 24, 2021 | 01:15 PM
Conanski's Avatar
Conanski
You could change the cam and it should make a difference in the way the motor runs.. how much I don't know. The Crane 444232 is a good option for an EFI motor, I had it in a 5.8 with ported heads and longtubes and loved it and others here have tried it and were happy with the results too. The big gotcha with these EFI trucks is it's pretty easy to exceed the limits of the fuel delivery system when mods are stacked up, and the native PCM is not really tunable for larger injectors like newer PCMs. Stinger performance makes a direct replacement PCM that is tunable nut that will add considerable cost to what is otherwise a simple upgrade.
Old Mar 24, 2021 | 05:57 PM
baddad457's Avatar
baddad457
A 108 LSA cam's not going to work well with EFI . The cam he has is pretty close to the stock F4TE roller cam in the 94-up 351's.
Old Mar 26, 2021 | 06:26 PM
DaveMcLain's Avatar
DaveMcLain
Really? The stock non HO 302 cam has a 108 lobe sep.
