6.0L no crank no start help
Old Feb 13, 2021 | 02:50 PM
  #31
DNB Solutions's Avatar
DNB Solutions
If you have all the fan coverage in place, the easiest way to hand crank is from under the truck; you turn the crank bolts like you were tightening them. But as Mark mentioned, if the starter IS engaging even with a hydrolock, you hear it engage.
If no bump, it's either the starter brushes or the solenoid that is the issue. If it's the brushes, a few taps with a hammer on the starter's front-facing edge can free them to see if the starter would now work, but it will need replacement. Not extremely hard to do, but intimidating the first time if not familiar.
But with the smoking, you've got other issues once it will rotate over,
ok so I was able to hand crank it. I tapped the started and still wasn’t getting any response so I took the opportunity to upgrade to the 6.4 starter. Got that installed charged the batteries and got it started. Not a lot of white smoke this time. One weird thing it did was it was ideling at like 900-1000 rpm after start for a good minute. I tapped the accelerator and it went down to 600-700. Is this normal?
Old Feb 13, 2021 | 03:12 PM
  #32
TooManyToys.'s Avatar
TooManyToys.
I can be. It's been so long since I've started a 6.0.
The lack of smoke is a good thing, it's possible your starter was spinning slow but just above the point of the PCM letting it run, but the fuel state wasn't optimum. Give it a couple more starts and see how it is.
Glad you got it running.
Old Feb 13, 2021 | 03:38 PM
  #33
DNB Solutions
I let it sit for about 45 min. Started right up very little smoke. Is it possible for the starter to have been the culprit for the extended crank when hot?
would should I be specifically monitoring on my scan tool to make sure everything is running correctly ?
I really appreciate all of y’all’s help !
Old Feb 14, 2021 | 12:50 AM
  #34
Euroman's Avatar
Euroman
When it's cold mine switches to high idle too after about a minute, presumably to speed warmup. Touch the brake or gas and it goes back to normal so you can drive away.
Old Jan 5, 2024 | 01:22 PM
  #35
Liam O.'s Avatar
Liam O.
2nd Gear
Simple fix
The other night after the gym I go to start my 04 F350 6.0 and nothing happened. Electrics came on and everything but it simply wouldn't crank, wouldn't even try. Ended up getting towed home, and after replacing the starter and oil pressure sensor it turns out that my automatic simply wasn't getting into park correctly. I still have yet to replace the part but if I just work it into park correctly it fires right up. Not saying that this is the fix for everybody but I would have saved myself time and money had I tried the gear shifter first, its such a simple fix
Old Jan 5, 2024 | 02:32 PM
  #36
Liam O.'s Avatar
Liam O.
2nd Gear
Simple fix
The other night after the gym I go to start my 04 F350 6.0 and nothing happened. Electrics came on and everything but it simply wouldn't crank, wouldn't even try. Ended up getting towed home, and after replacing the starter and oil pressure sensor it turns out that my automatic simply wasn't getting into park correctly. I found a good video on fixing it, you just need to remove the panel underneath the steering wheel and tighten some screws. Now it turns over with no issues. Not saying that this is the fix for everybody but I would have saved myself a lot of time and money.
Old Jan 5, 2024 | 04:07 PM
  #37
bismic's Avatar
bismic
@Liam O. - thanks for the post and the information.
Old Jan 8, 2024 | 06:56 AM
  #38
IHateCommieCars's Avatar
IHateCommieCars
Well-known problem. If you'll look in the tech folder here, Mark's no-start checklist includes that and many other things one would check before shelling out for a starter. Sorry you didn't see it first. Maybe save you money next time.
Old Jan 9, 2024 | 07:59 AM
  #39
Byrd.Dog's Avatar
Byrd.Dog
It will also start in neutral. I've had to do that before when I had a brake sensor going out.
M.Lusk
1997 - 2003 F150
Jan 31, 2021 08:57 PM
Fordguy1974
1997 - 2003 F150
Nov 15, 2019 11:41 AM
kylant
Apr 23, 2017 03:48 PM
Lost_Arkitekt
Oct 25, 2009 05:53 PM
88 f150
Jun 7, 2007 01:55 PM
