Sponsored by: Auxito
1992 crank no start
Old Nov 14, 2019 | 07:38 PM
Fordguy1974's Avatar
Fordguy1974
1992 crank no start
I have a 92 150 auto will crank no start. You can spray starting fluid in it and it will attempt to crank after a min but only for a sec.
Old Nov 15, 2019 | 09:20 AM
alloro's Avatar
alloro
It will "attempt to crank" or attempt to start? If it starts, can you keep it running by giving it additional blasts of starting fluid?
Old Nov 15, 2019 | 10:32 AM
Fordguy1974
1992 crank no start
Reply is it only attempts to start for only few seconds does not start at all.
Old Nov 15, 2019 | 11:38 AM
pdqford's Avatar
pdqford
But it keeps cranking over, just won’t start?
Old Nov 15, 2019 | 11:41 AM
Bluegrass 7's Avatar
Bluegrass 7
Something to note:
If the motor cranks and begins to run in the crank mode, then stops when back to Run, suspect the TFI.
Reason is, there are two feeds.
One for cranking to boost ignition spark and one for running.
If the running circuit goes into fault the motor will stall when cranking is exited.
Murf-150
1997 - 2003 F150
Oct 25, 2019 12:07 AM
kylant
Apr 23, 2017 03:48 PM
88 f150
Jun 7, 2007 01:55 PM
explorerdad
Sep 5, 2001 06:39 PM
