6.0L no crank no start help
that’s a good point. I had just pulled them to see if they were blown. I’m going to have to get some more multi meter probe tips I guess.
I'd get the starter working first so you can guarantee at least 150 rpm when cranking. Sounds like it is bad starter as long as the + cable from the passenger battery is making good connection at the starter.
I guess the engine could be hydrolocked also Have you had any excess smoke when starting (ie either raw diesel in the exhaust or coolant)?
As stated above - direct power to solenoid and direct power to the starter - If it doesn't spin that way, then it is time to hand crank!
what is the proper way to hand crank? I’m having trouble finding anything on it
I do it off of the harmonic balancer. Rotate it clockwise while looking at the balancer from the front of the engine. Chock the wheels and put it in neutral to rotate it.
https://www.justanswer.com/ford/3531...ft-valves.html
Not to be grammar ****, but Bizmic left out a comma after "vacuum pump" and I just want to make sure you understood where the starter wire is. Correct me if I'm wrong, guys, but when my bus hydrolocked, the starter knocked when I tried to start it. I could hear it bumping the flywheel, it just couldn't turn it. OP, does your starter make any noise at all? If not, I guess you can still try to hand crank to confirm, but I'd say you need a starter.
Do I need to remove anything to gain access to the bolts or is there a certain angle I need to be in to access them ?
If you have all the fan coverage in place, the easiest way to hand crank is from under the truck; you turn the crank bolts like you were tightening them. But as Mark mentioned, if the starter IS engaging even with a hydrolock, you hear it engage.
If no bump, it's either the starter brushes or the solenoid that is the issue. If it's the brushes, a few taps with a hammer on the starter's front-facing edge can free them to see if the starter would now work, but it will need replacement. Not extremely hard to do, but intimidating the first time if not familiar.
But with the smoking, you've got other issues once it will rotate over,
