Idle only miss
Old Jan 26, 2021 | 06:59 PM
cmayer's Avatar
cmayer
Idle only miss
2001 Excursion V10. New engine about 30k (initially put 3k on accident) miles ago. All COPs replaced at that time. Went to hook up the trailer last weekend and noticed a consistent miss only at idle. Has plenty of power, pulled a trailer to put a load on it and couldn't replicate the miss off idle. As soon as it's back to idle it has a consistent miss hot or cold.
Noticed the PCV hose that has insulation wrapped around it doesn't look to be in the best of shape, so ordered one from the local Ford dealer and it'll be here Thursday.
In the meantime, any other common causes of a miss at idle? No check engine light or codes.
Old Jan 26, 2021 | 07:54 PM
bluovl's Avatar
bluovl
It’s really hard to diagnose these trucks without the help of a scanner. There are so many things that are interdependent that could cause a miss. I’m assuming you have replaced plugs and cops with the new engine. Could be a bad connector (injector or cop). I doubt it’s fuel related because it only occurs at idle. A scanner may not even help if the miss doesn’t exceed the threshold. Then again if you have not replaced coils and plugs it might be a good place to start. Sorry not much help.
Old Jan 27, 2021 | 05:33 PM
cmayer's Avatar
cmayer
Thanks, going to take it to a shop and see if anything shows up on the scanner. Only other way I can think of is to replace each COP and boot one at a time and see if it clears up. We did have more humid weather and then rain, and from what I've read that could be associated with a cracked boot. Just strange that it only misses at idle and no noticeable shaking or power loss once moving.
Old Jan 27, 2021 | 06:07 PM
Dweber85rc's Avatar
Dweber85rc
If it was moisture related it should clear up after things have warmed up and evaporated. . It could also be a coil on plug electrical connector.
Old Jan 28, 2021 | 08:52 AM
jayro88's Avatar
jayro88
I had a miss that seemed to only appear at idle. First time I noticed it was after towing my camper for the first time. Mine did eventually throw a code.
When I examined the COPs I noticed the clips holding the plugs on them were broken. I unplugged each one, cleaned them with electrical contact cleaner and then sprayed them with di-electric. I haven't had an issue since.
I think Forscan can tell you which cylinder is missing. The regular code reader only told me that a cylinder was.
Old Feb 2, 2021 | 10:49 AM
cmayer's Avatar
cmayer
Turned out to be the boot on #10. Used the torque app with a cheap OBD Bluetooth reader to see which cylinder was having issues. #10 was right below the limit of throwing a code according to the app. Replaced the boot and it smoothed right out.
Resting my hand on the extended tow mirror I can feel a real slight miss and #4 and #6 showed a low misfire count, so I'll go ahead and replace those boots as well. Also replaced the PCV and associated hoses as they looked to be in poor condition, but that was after the main miss was corrected.
Old Feb 2, 2021 | 11:35 AM
WE3ZS's Avatar
WE3ZS
Did the new COPs 3K miles ago come with new boots? And one of those new boots failed? Just curious as that isn't a common issue that I've seen or read about.
Old Feb 2, 2021 | 12:43 PM
cmayer's Avatar
cmayer
Should have clarified that I typoed the mileage and the shop that did the engine install did not replace the COPs or even boots as part of the "install package". Basically they put a long block in and cleaned up the old accessories. I should have done a lot more follow up than I did and won't be using that shop again as the conversation after this was not friendly.
The boot didn't look particularly bad, no visible cracks however the new boot made an instant change to smoothing out the idle. No more misfire unless I'm really feeling for it. Like I said only noticeable with the tow mirrors full extended and resting my had on it can I feel a slight vibration out of normal in the idle.
The PCV hose didn't look bad except the insulation around it was cracking and I didn't want it to make a mess, so replaced it. Taking it off it was pretty oil saturated and the boot at the end was quite frail.
Old Feb 2, 2021 | 08:06 PM
WE3ZS's Avatar
WE3ZS
Yep, old boots are a miss looking for a home! Those rubber boots live in a pretty tough environment that causes them to break down over time and miles. Glad that you got it sorted out!
toobzrn
Jan 19, 2016 11:20 AM
Biggziff
6.7L Power Stroke Diesel
23
Jul 28, 2011 06:06 AM
Joe Meg
Oct 25, 2010 05:32 AM
snsgraham
Modular V10 (6.8l)
Jul 5, 2006 02:41 PM
