autolite 4100 choke question..
Old Jan 5, 2021 | 09:28 AM
Clinton N's Avatar
Clinton N
I have a C5AF-H off a 65 Galaxy. the original choke had several issues possibly from a drop. The tangs that lock into the coil spring was snapped off, the heater choke connection was cracked and the top of the pull off piston bore dented. So I found another However it has the same body Mounts exactly the same but uses an external pull off I believe its 70-72 era.. Now I'm going electric choke will i even need the choke pull off ? I now have the tangs that work with a choke coil so I'm thinking I might be good any suggestions?
Feb 23, 2016 04:46 PM
Ford4ever4me
Jun 4, 2008 03:10 PM
Ford4ever4me
May 6, 2008 02:42 PM
oildude
Oct 23, 2004 03:35 PM
tamarackstyle
1978 - 1996 Big Bronco
Dec 2, 2001 03:26 PM
