1978 - 1996 Big Bronco
HOLLY 4180 choke
Old Nov 30, 2001 | 09:37 PM
tamarackstyle's Avatar
tamarackstyle
HOLLY 4180 choke
heres what I got. an '86 351W with a 4180. my problem is my elec. choke. as far as I can tell the choke is non adjustable (as most everything else on this carb). the choke cover retaining plate is riveted on,with only one screw. also there is an external vacume choke pull of with an internal bleed. so i have two questions (mabey three). ONE: does this choke use a thermostatic spring that would be adjustable If i were to replace the rivets with screws? Two: If i can now adjust the choke from step one would the external pull off be necessary? THREE: If all else fails and I convert to a manual choke do you see any problems with me removing the pull off and blocking the internal vacume bleed? Thanx a million
Old Dec 2, 2001 | 03:26 PM
albertaguy's Avatar
albertaguy
HOLLY 4180 choke
yabadaba
May 15, 2016 10:29 AM
Tkc432
Jun 27, 2015 01:00 PM
1986F150six
43
Mar 1, 2015 06:24 PM
fairfield86f150
42
Mar 15, 2012 02:13 PM
big hoss 29
Feb 18, 2005 09:00 AM
