7.3 Issue?
Old Jan 6, 2021 | 07:36 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by 00t444e
I can shift mine in and out of 4x4 low while rolling at 2-3 MPH without my foot on the brake.
The OP has ESOF best I can tell, not a manual transfer case, like you. Your experience/method does not work with ESOF.
I suspect you are simply tricking your truck into thinking it is stopped so you can move the transfer case lever into 4 low.
Old Jan 6, 2021 | 08:25 PM
00t444e's Avatar
00t444e
Yes on an esof you have to be stopped and in neutral on an auto, clutch in on a manual and have your foot on the brake before it will tell the shift motor to switch it to 4x4 low. On a manual 4x4 system like I have none of those safetys exist. I can shift it with or without my foot on the brake when stopped or moving slightly and in gear with the clutch pushed in or in neutral with the clutch in or out doesn't matter. I can shift it much quicker than the electronic 4x4 will as well, it will shift from 2wd all the way to 4x4 low or from 4x4 low back to 2wd in a second.
Old Jan 6, 2021 | 09:20 PM
RacinJasonWV's Avatar
RacinJasonWV
You need to have the transmission in neutral or the clutch pushed in to shift into 4x4 low on any manual or electronic shift transfer case.
I was referencing the OP’s ESOF with the main point being it will not shift to 4 Low while in Park. With an auto trans it must be in Neutral. I didn’t realize this at first and was trying to do it while in Park.
and stopped... no shifting into 4 LOW in motion. Also, the brake must be on as well...
Oops I didn’t even realize it had to see the brake on as well. Thanks for sharing and clearing this up.
Old Jan 6, 2021 | 09:55 PM
Sous's Avatar
Sous
FTE Emeritus
Sir, with all due respect, we realize that you have a manual transfer case lever and can manipulate the lever in a way that Ford does not recommend based on the literature provided with the vehicle purchase. Although, the OP has an ESOF system, so statements regarding the shifting into or out of 4x4 Low would be beneficial to the OP if they were described as Ford requires.
Most of us are familiar with how a manual transfer case lever works and have owned vehicles with such a lever. You are clearly very proud of your second shift lever, as I would be as well. It took me a year to find my truck with a ZF6, no rust and within my budget. if I needed the manual TC lever as well, I probably never would have found a truck. For those that don't know about a manual transfer case lever, they now have the information and method Ford recommends and the information and method you use. Either way, this has zero to do with the ESOF system requirements of shifting into 4x4 Low.
My apologies to the OP for the derailment.
Old Jan 6, 2021 | 09:59 PM
Sous's Avatar
Sous
FTE Emeritus
A few months back an FTE'r thought he had a broken transfer case shift motor because his truck was "stuck" in 4x4 Low. A few of us commented and I told him he could shift it manually by hand if needed.
SSJ came in and told him to be in neutral, brake on and turn the ESOF ****. Low and behold he was no longer "stuck" in 4x4 Low.
Old Jan 6, 2021 | 10:23 PM
00t444e's Avatar
00t444e
To anyone wanting to get rid of the ESOF, a manual transfer case swaps right in, you don't even have to cut a hole in the floor for the lever there is a plug in there already. All you need is the transfer case, shift linkage, shift lever, and the boot and trim piece.
Old Jan 9, 2021 | 08:37 AM
Sous's Avatar
Sous
FTE Emeritus
Swaps right in is a bit misleading... It is not a plug and play USB stick or a seat that has 4 bolts... There is a significant cost (if $1000 is significant to you) and a good deal of time involved in swapping an electronic shift for a manual shift transfer case.
Transfer case - ~$750 for rebuilt not from a salvage yard
Other associated parts can be found here at various prices - https://torqueking.com/category/shif...r-ford-nv271f/
I have also included the removal and installation procedures from the Ford Service Manual if the advice from Ford is something someone prefers to follow and finds this thread in the future.
Tagging @Y2KW57 for a couple of reasons...
1. The nomenclature used for the "transfer case removal" and "shift lever removal" in the 7.3L PSD Tech Folder is listed as 306-07B and it should be 308-07B.
2. Please include the "transfer case installation" procedure if you feel it is a worthy addition.
Old Jan 9, 2021 | 09:17 AM
00t444e's Avatar
00t444e
You can get all the parts to swap it for $500 or less at a junkyard. Not that hard to swap all you have to do is unbolt the two driveshafts, unplug all the connections, take the 6 bolts out and remove the transfer case, bolt the new one in, bolt the shift linkage, lever and boot in, reconnect the driveshafts and splice a couple wires so your 4x4 lights work.
Old Jan 9, 2021 | 09:28 AM
Sous's Avatar
Sous
FTE Emeritus
Clearly you have your own way of doing things, but not everyone has the talent, tools, experience or ability you have. I commend you for summarizing the processes I provided and reducing the cost and labor estimate.
I specifically mentioned a salvage yard above and the provided very specific/detailed instructions for removing and installing a transfer case according to Ford. Sometimes we as owners deviate from what Ford says, I do this myself.
The point of my post with documentation and correction suggestions to the 7.3L PSD Tech Folder were for future readers that stumble upon this thread in the future, not to incite another debate.
Thank you for your contribution to the thread, it has been and will be a learning experience.
Old Jan 9, 2021 | 09:55 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Resendiz
23
Aug 7, 2016 07:48 PM
7.3 forever
15
Nov 7, 2015 08:57 AM
Baatzy
Aug 26, 2015 06:21 PM
1973dieselhighboy
31
Feb 5, 2013 09:50 PM
DBrewer
Dec 8, 2004 04:10 PM
