Stall under Acceleration: 2nd Time
Old Feb 10, 2021 | 08:40 AM
  #76
RainDesert's Avatar
RainDesert
Good to know Raven. Really hoping you can find the fix.
My update is 5 star didn't fix it. I recently read a thread about a hidden "sport mode" and I have been running it for the last 2 weeks. My truck is definitely more responsive in that mode, and I thought the "stall" or "dead pedal" was almost gone, but the other day getting onto the freeway, it didn't accelerate again for about a 2 second hesitation. I'm starting the think the only fix is something more major and something I don't have much more time and patience to get fixed. What I have tried:
TC off
Advance track off
Both off
Sport mode
5 star
Old Feb 10, 2021 | 06:05 PM
  #77
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by raven_zilla
Last night downshift to 3rd under WOT, the transmission held 3rd gear for almost 10 secs *after* throttle was released. 3rd gear/4800 rpm for 10 secs until I feathered the throttle to get an upshift. This transmission (10R140) is a mess for me.
That is somewhat normal. Maybe not a full 10 seconds, but my 2018 does the same.
Old Feb 11, 2021 | 06:08 AM
  #78
Altoidfishfins's Avatar
Altoidfishfins
Interesting. I have a '19 F250 with the 6.7 Power Stroke about 10k miles and can't recall seeing this. I have 3:31 gears 4x4 6R140 trans. Built June '19.
Knowing this I'll try to replicate it in a safe situation so that at least I can be aware of it and add it to the info here.
Is this mainly an issue with trucks that have the 10R140 and 3:55 (or numerically higher) gears? Or is that one of the things that still needs to be determined?
Old Feb 11, 2021 | 02:46 PM
  #79
chamdaddy's Avatar
chamdaddy
Definitely taking it in to the dealer. I can replicate the stall/hesitation under slow roll most of the time. Last night downshift to 3rd under WOT, the transmission held 3rd gear for almost 10 secs *after* throttle was released. 3rd gear/4800 rpm for 10 secs until I feathered the throttle to get an upshift. This transmission (10R140) is a mess for me.
I have never experienced hesitation or dead pedal but I occasionally do get the prolonged downshift. In my case, it always occurs while I am in Tow/Haul mode and when I step into the pedal and then let off. I just assumed it was a glitch in the programming thinking it was needing to provide engine braking upon letting up on the pedal. If I quickly switch the mode to eco or normal it immediately upshifts as it should. I agree it is annoying and does not feel right, hopefully it is a matter of better programming but it has been a year and we have not seen a resolution.
Old May 17, 2021 | 09:13 AM
  #80
Lin19687's Avatar
Lin19687
Veteran: Navy
Has anyone taken it in and they actually fixed something, beyond just redoing the Learning Program ?
They did that for me as well as tweek the torque bolts hitting the bell housing but I still have the issue
Old May 17, 2021 | 09:45 AM
  #81
grumblin's Avatar
grumblin
I'm about to go down that path. The truck is a beast at 2k RPM - off idle, i'm afraid it's going to kill me - and that's no joke.
Old May 17, 2021 | 10:18 AM
  #82
raven_zilla's Avatar
raven_zilla
took mine in a couple of weeks ago and the service advisor said that they could not recreate but they did put 25 miles on the truck trying to replicate the problem. 🙄 The truck has grown on me, esp. the 7.3, but the dead pedal issue is dangerous. I have a Ram 2500 on order.
Old May 17, 2021 | 10:26 AM
  #83
scraprat's Avatar
scraprat
Top Answer: 5
After 2 months and 8,900 miles driving in different conditions and pulling the toy I haven't experienced the dead pedal. Hope you guys get it figured out.
Old May 18, 2021 | 05:27 AM
  #84
Lin19687's Avatar
Lin19687
Veteran: Navy
Please don't get me wrong I love my Loch Ness. But she's got some issues that need to be fixed before I start to haul Cattle. Horses wouldn't be an issue, you can take them out if you break down... not cattle
Old May 18, 2021 | 06:02 AM
  #85
BGMSPD's Avatar
BGMSPD
I've had the loss of power a couple times now. 21 F250 Lariat Tremor 7.3 with 4.30's. Usually occurs when I slow down for a speed bump leaving my development and after going over the bump I try to accelerate and it falls on it's face. Just hit 4K miles and not liking this one bit. And then add that to the high idle issue and the truck lunging makes me want to go back to my 17 F250 Platinum 6.2 which drove beautifully. I did notice that driving in ECO mode seemed to help a bunch with the lunging, but don't recall is if did anything for the loss of power. I'll have to try and see if it makes a difference.
F2502011
Jan 19, 2019 01:04 PM
metfancowboy
6.7L Power Stroke Diesel
Jan 3, 2015 11:06 PM
Pool Runner
2009 - 2014 F150
Jan 13, 2014 10:54 AM
fastbee
May 9, 2011 01:31 PM
jlphelan1310
Oct 15, 2010 10:34 PM
