Just a footnote but I bought the tunes from 5 star and it did not in any way help with the issue. They were very good about trying to tweak the files but I have given up on it and am back to stock. So don't think that is a silver bullet so to speak. I think in person tune or some data logging to catch the issues might work but the canned tunes for me did nothing. But again they did try to work on the tune files and never gave me any grief at any point.
When these Incidents occurred, were either of these a U Turn OR is it Only on Left Turns? Last Week, on 2 different days, I pulled out of our Parking Lot and was going to make a Wide Left U-Turn. While making the Left U-Turn, just as I was completing the Turn, I pushed on the Accelerator and the Engine Reved, but nothing else happened. This was not a Fast or Quick U-Turn. The Best Way I can Describe it is it was like the Left Tire was Off of the Ground. It kind of makes your backside Pucker when oncoming traffic is approaching, and you feel like the Turtle crossing the Roadway. The Road is a 4 Lane Road, with a Median, and I was turning from the SB Outside Lane to the NB Outside Lane at around 5 mph, maybe.
It was if all of the Transmission Fluid has gone to the Right Side of the Pan, and the Transmission quit working, for those couple of seconds, until it finally engaged.
Is this just being experienced with trucks having 3.55 gears or are other with 3.73 & 4.30 experiencing this also?
I've been going back and forth between a 250 with 3.55 or 350 with 3.73 (I like 3.73 more and can only get with the 350). If this hesitation is with the 3.55 then it's an easy decision which to get.
Surely this Isn't Normal, IS IT?
1st time was passing on a 2 lane highway. The truck hesitated before downshifting. There was enough of a hesitation to abort the pass. I attributed that to the transmission logic not being able to quickly and correctly determine the appropriate downshift. I've had that happen several times especially if the truck is in 10th gear.
Last night was more of a no power situation. The more I think of it, I'm not so sure that it was the TC kicking in. I've had TC kick in during rain while turning/merging into traffic. This wasn't a power/reduced power/power situation. This was more like no power/ no power/power.
I'll probably file a NTSB/DOT compliant later today after I contact the dealer.
I'm not really following how a rear end ratio can cause hesitation? The rear end is always connected to the drive line, receiving whatever power the transmission sends. Even with LSD and E-Locker rear ends, it's always receiving power from the transmission, is it not?
Admittedly, I'm relatively new to these trucks and this isn't my field of expertise, so I'm just trying to understand the logic behind blaming the rear end gear ratio.
My truck does the same thing. 2019 F-250 PSD with 3.55 E- locker diffs. It is caused by the traction control system and the stability control system, in my opinion anyway. Trying to make a 90 degree turn from a stop while jumping on the throttle seems to be a forbidden practice. I haven't tried deactivating both systems yet. Supposedly holding the button for 5 seconds deactivates everything.
My truck sounds like your twin. FWIW my truck was built December 2019.
F250 has offered 3.73's since the Super Duty was introduced in 1998 as a 1999 MY. Now, in 2020 they remove them.......just so ridiculous.
Me neither but so far 3.55 gears seem to be the thing in common.
I have 3.73 in mine and never experienced what your talking about. The sluggish response was fixed when I tuned it. I put it back to stock a couple weeks ago just to see after driving tuned for almost a year the truck is a flat out turd with stock tune.
Search YouTube for above, every video I've seen so far everyone is all smiles. I would watch the Banks video about the product where he talks about the design and safety features.
Since this is an intermittent issue, your best bet is to contact the dealer to see if there is a known issue and fix. Also try to figure out how to reproduce it, go to open parking lot and see if you can figure out what makes it happen. Intermittent issues are difficult to correct, be aware that if you drop it off at the dealer it may be there a while for them reproduce it and fix it. So if you can reproduce it you can demonstrate it to them and get it addresses.
It could be an overly sensitive traction control or stability control causing it to kill power. Traction control seem to take a few seconds before it will kill power, I think it applies brake first, before reducing or killing power. The stability control does react pretty quickly when it senses that the front and rear are not tracking. Depending on how much oversteer, understeer, drifting, etc the stability control senses, it will react differently by cutting power, applying brakes on specific wheels, etc. It looks at wheel speeds, steering angle, pitch, yaw and few other things and the rate they are all changing to determine when and how to intervene.
I'll make a left hand turn, in front of oncoming traffic, with the service advisor in the passenger seat to see if I can replicate...
