Tuning issues
Old Nov 28, 2020 | 07:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It sucks that your problems weren't transposed from one truck to the other because I would have you run the 180/30 tunes in place of the 160/0s (auto tunes in the manual); chances are your problem would disappear due to pulse width being pulled from the 30% tunes. I would do it myself but I know how the automatic transmission would function with manual transmission tuning and would not advise blindly jumping into it.
Old Nov 28, 2020 | 07:11 PM
ESwift's Avatar
ESwift
CNCFAB
Originally Posted by cleatus12r
It sucks that your problems weren't transposed from one truck to the other because I would have you run the 180/30 tunes in place of the 160/0s. Chances are your problem would disappear due to pulse width being pulled from the 30% tunes. I would do it myself but I know how the automatic transmission would function with manual transmission tuning and would not advise blindly jumping into it.
My auto with the ac's has a hydra with titan unlock, I could run tunes for %30 nozzles and the auto tuning to see if it would help, but the php shifting doesnt agree with my truck.(no vb tunes on titan unlock)
Old Nov 28, 2020 | 07:12 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Well......
A few miles of gentle accelerations and then a couple deceleration events might show whether it helps or not.
Old Nov 28, 2020 | 07:15 PM
ESwift's Avatar
ESwift
CNCFAB
Well......
I will give it a try on Monday.
Old Nov 28, 2020 | 07:20 PM
udsuth78's Avatar
udsuth78
That log looks similar to mine after the swap to 160/30's and had a tuning mix up. Singles on split tuning had mine bucking and surging on deceleration. Worst on cool mornings, lile trying to drive a top fuel dragster through a school zone. Come to think of it they were also the GH's that didn't match my PCM. Doubt that's helpful but never know. Good luck
Old Nov 28, 2020 | 07:25 PM
ESwift's Avatar
ESwift
CNCFAB
GH def sent me split tuning and it was not so great, they corrected and it is better.
But this truck does it with tunes from SDK, Jelibuilt, PHP, and AA.
1023 doesnt, they run smooth, but the shifting needs work, and are smokey. Lots of attemots to get shifting where I want it. Holding off to see if Dusty can live tune when he gets out this way next year.
AA has perfect shifting and great power. Reslly want this tune to smooth out, as it does everything almost perfect, daily ir towing, or playing.
GH has very good shifting, less bouncing all over
​​​​​​then others, but power is not so great.
You also had dpc422 programming trying to run on a dpc402 correct?
Old Nov 28, 2020 | 07:43 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I'm curious how your injectors would fair on the test bench.
Old Nov 28, 2020 | 07:48 PM
ESwift's Avatar
ESwift
CNCFAB
Me too, a flow bench test may be an option after the zf6 swap on my friends truck, and I get mine that he has borrowed for over 3 months back.
I need to give you a call at some point, as I mentioned in another thread.
I would prefer to get this fixed with tuning and not go through the work and expense of sending them to ya unless need be.
Also way too busy with other life matters right now.
Old Nov 28, 2020 | 07:51 PM
Bitterroot Diesel
Former Vendor
Tuning isn't going to fix a hardware issue if that's what it is. Seems you have almost exhausted all of your software options.
Old Nov 28, 2020 | 07:53 PM
ESwift's Avatar
ESwift
CNCFAB
I agree,
But since 1023 can make this issue gone, the other tuner that has everything else perfect *should* be able to as well
Old Nov 28, 2020 | 08:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The part in bold is why I suggest that it's a tuning issue and NOT a mechanical issue.
Old Nov 28, 2020 | 08:14 PM
Bitterroot Diesel
Former Vendor
How do tuners with a decade of experience get it wrong?
Old Nov 28, 2020 | 08:15 PM
  #28
ESwift's Avatar
ESwift
CNCFAB
Cause my truck is a unicorn?
Old Nov 28, 2020 | 08:24 PM
  #29
cleatus12r's Avatar
cleatus12r
Butt-Head
Blame it on the voting machine software. I mean, it IS Pennsylvania.
Old Nov 28, 2020 | 08:48 PM
  #30
ESwift's Avatar
ESwift
CNCFAB
