Mississippi Chapter Join Chapter , Leader: Scndsin
Just October
Old Oct 29, 2020 | 08:27 AM
  #61
Meridian_Mike's Avatar
Meridian_Mike
Oh yeah!!!!
NOW, I could deal with that!
Great work David!!
(I can actually see a valve cover!)
Old Oct 29, 2020 | 08:37 AM
  #62
56panelford's Avatar
56panelford
Originally Posted by Scndsin
This is the last/most recent iteration of mine, MAF conversion Mk II:
That's what I'd like to achieve in a different engine bay.. I knew there was a motor somewhere under there...lol
Were those pictures enough to tell you the story on this one of mine or do you need more..?
Old Oct 29, 2020 | 03:18 PM
  #63
Scndsin's Avatar
Scndsin
I see a lot of AIR equipment but can't tell if the pump is still under the alternator. Reason for curiosity is the belt wrap on the alt looks to be in the deleted position.
A sharp shot of the drivers side of the manifold would be good.(there's 57 varieties of plumbing) Like to know if the diagnostic connector is still in the corner of the drivers fender & firewall.
Old Oct 29, 2020 | 04:41 PM
  #64
56panelford
Here's some more pictures
Pulley was removed from the air pump
The wiring under this is a real mess putting it politely..
Old Oct 29, 2020 | 05:28 PM
  #65
Scndsin's Avatar
Scndsin
Wow. That's a mess. Those loose relays are scary. Think I see the diagnostic harness back behind them.
Yeah it can go on a diet. Pump is still there. Shame you can't work on it over winter. They hate not running.
Old Oct 29, 2020 | 06:27 PM
  #66
56panelford
First time I seen this truck was 5 years ago when I was looking for a transmission for my pickup, this being a manual I wasn't interested in it at the time. When I dragged this M350 home plans were to have a flat bed truck with DRW and I like the 5.8 in the pickup and the manual for this truck seems fitting. Truck sat there all this time and he told me it ran. I paid him the $250 he wanted and when I got it home I put some gas in the tank which I found out after had a hole drilled in it to drain what ever fuel was in it put a battery in it and it started right up. It idled nice and smooth And drove pretty good too
Old Oct 29, 2020 | 06:30 PM
  #67
56panelford
There is a plug I meant to get in the picture that has a cap on it that is about 2 1/2" wide..that is resting above the two relays..
Old Oct 29, 2020 | 09:27 PM
  #68
Scndsin's Avatar
Scndsin
Should look like pic in post 63, minus the jumper.
Old Oct 30, 2020 | 08:01 AM
  #69
56panelford
Going out of town today but will check when I get back home but I do believe I seen a plug that looked like that..
Old Oct 30, 2020 | 01:25 PM
  #70
Scndsin's Avatar
Scndsin
Yeah that plug is important & frequently the recipient of butchery.
Time to drag out the Harbour Freight green-house from behind the shop & throw it together for 6th-7th season.
Frost soon & the tropicals will be un-happy.
diesel-fitter-bum01
16
Dec 5, 2011 11:20 PM
JHoffman93
Oct 7, 2009 10:10 PM
97Centurion
Kansas Chapter
41
Dec 10, 2005 04:16 PM
IronFord
Aug 10, 2005 12:15 PM
stein78
Nov 26, 2003 09:11 AM
