Mississippi Chapter Join Chapter , Leader: Scndsin
Just October
Old Oct 20, 2020 | 03:55 PM
  #31
Meridian_Mike's Avatar
Meridian_Mike
Hmmmmmmmm
I better alert my nephew about this
Old Oct 22, 2020 | 08:54 AM
  #32
5_labsownus's Avatar
5_labsownus
Fantastic Thong Thursday Mississippi, David, Mike and crew.
It would be nice to have a big piece of that tree. I have seen some of the Woodwrights here use steel band on large tree sections while drying.
Old Oct 22, 2020 | 08:58 AM
  #33
Meridian_Mike
Yep....
I am going to try to make sure my nephew doesn't start cutting up that tree trunk into slabs until he gets some advice from someone who KNOWS how to deal with it.
Old Oct 22, 2020 | 10:15 AM
  #34
Scndsin's Avatar
Scndsin
Nice sig line, Mike. More folk should use that tool here.
Old Oct 22, 2020 | 10:34 AM
  #35
Meridian_Mike
Thanks!!
I just figured it out yesterday.... I thought I would give it a try... I thought it would be fun.
Old Oct 25, 2020 | 04:24 PM
  #36
56panelford's Avatar
56panelford
Here's a sample.
That motor sure does look nice, exactly what I have to put in my 56 Mercury but mine will need a lot of work to look that pretty. Do you have a build thread for it..
Old Oct 25, 2020 | 08:08 PM
  #37
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Im still hoping to see how it turns out myself. Looks much better in the truck...
Old Oct 25, 2020 | 09:25 PM
  #38
Scndsin's Avatar
Scndsin
Hi John. Almost finished with the install. I'll do a thread primarily on the modded intake, I'll PM a link if you don't see it.
Old Oct 26, 2020 | 07:52 AM
  #39
Meridian_Mike
WOW... I want to read that thread too.
Please post a link.
Old Oct 26, 2020 | 08:03 AM
  #40
56panelford
That would be great and much appreciated..thanks
Old Oct 26, 2020 | 08:07 AM
  #41
56panelford
Will there be much eliminated from the original factory clutter of hoses that hide 90% of the motor..
Old Oct 26, 2020 | 01:31 PM
  #42
Scndsin's Avatar
Scndsin
There's a lot gone already, but we're used to the differences.
Air pump & plumbing is gone. shorter belt. TB cooling, conversion to electric fan inside stock shroud with adjustable thermostat.
Manifolds to headers, Solenoids eliminated save for EGR, wiring cleaned up. coil mount cut down. Cut the ears off the E4OD for better removal.
Head light relays & battery power direct, rather than through the switch. It'll have an catch can eventually. Little things, but they add up to easier living & performance.
Old Oct 26, 2020 | 01:33 PM
  #43
Scndsin's Avatar
Scndsin
This is "stock":
Old Oct 26, 2020 | 04:20 PM
  #44
56panelford
This is "stock":
Yours is quite a bit cleaner than the one I have...lol
Old Oct 27, 2020 | 08:01 AM
  #45
Scndsin's Avatar
Scndsin
John, haven't looked at your build in some time & had to go back & catch up. Really marveled at your welding skills & ability to make swiss-cheese look good.
Haven't made it past '16. Are you re-motoring?
