rush of air under the hood???
12-01-2011, 02:21 PM
on
On cold day warm ups,while driving,it will dump any and all boost. Sounds like someone has an airhose under there and its wide open. Truck runs fine,I'm not gettin.g after it neither. I do have an exhaust leak I'm fixing this weekend. WG is disconnected,aih removed. Can't think of anything else. What's your ideas. Maybe broken WG?
12-01-2011, 02:26 PM
EBPV engaging would be my thought, shouldn't make you lose it under the hood though.
it is the ebpv closing to warm up the motor faster and to me it is a pain.
12-01-2011, 02:31 PM
Unplug the EBPV at the base of the pedestal and forget about it....
12-01-2011, 02:36 PM
on
Will try that. Thanks for the help Al.
12-01-2011, 02:39 PM
if you just unplug it it will code you can put a resistor on it to stop than.
12-01-2011, 02:40 PM
here is the size
470ohm resistor
12-01-2011, 02:54 PM
on
Would it be the ebpv when I'm driving though? I know it does it on idle,never heard of it doing it while driving.
12-01-2011, 02:55 PM
Yes. It will engage while driving and do just as you describe.
12-01-2011, 02:57 PM
in my truck it is not to bad in my dads zf6 it will knock the power to nothing.
12-01-2011, 03:22 PM
on
Will any 470 ohm resistor work? I see they have different watts.
12-01-2011, 06:19 PM
You will want a 1/2 watt resistor at least. It is only a soft code and will not activate the SES
12-01-2011, 06:24 PM
on
Ok,thanks. I will pick some up tomorrow.
12-01-2011, 07:42 PM
on
Can I fix this issue or is the resistor the best fix for this problem.
12-01-2011, 07:45 PM
you can just unplug it and it will be ok it will just code.
