Anderson Ultimate VS the Pullrite Super light,
#63
#64
Denny
#65
#66
So here is the Manual for that Pullrite Superlite 2600 you will see how it's done.
https://www.pullrite.com/sites/defau...nual-proto.pdf
#67
#68
I downloaded the 2400 manual and answered my question, there's 3 bolts and jam nuts that hold the receiver tube from moving after you adjust the height. The thing is just to simple so I'm over thinking it but I will have to come up with a way to know how when I'm over the reciever because of my tool boxes I won't be able to see it.
Denny
Denny
#69
Denny, might consider using a lanyard or something that you can attach to the middle stake box pockets. They are directly over the hole for the ball on gooseneck applications.
I use one with a mark on it right in the center above the ball. On the goosebox, I have a dot and line up the line and the box dots. Then back up until they are fairly close and then check.
Works for me so don't if that would help in this instance or not.
#70
Denny
#71
In most all cases I can get it in the first try. This is a very solid hitch, since I had it now I have put about 6000 miles using this hitch. And not one time I have any problems.
#72
#74
I agree it is beefy and solid I look forward having this one for a long time.
#75
