Anderson Ultimate VS the Pullrite Super light,
"I turned the red adapter to the rear, which shortened up the entire combo by about 8-9”."
I watched an installation video on You tube and they show the ball cone on the back side of the king pin. Is that correct and what are all of you doing? Seems to me leverage would be a problem and want to pull it side to side mounted to the back. Is there a way to mount it in the front? Love the idea of hanging it on a wall when your done. Only 1 so far has the Pull Rite maybe it comes down to price and where do I get one from.
Tom in PGH in that video they said if it was a long bed to face it towards the front and a short bed towards the back.
I have it facing the rear, so that it moves the pin box forward a few inches and then it clears the bed rails, which have the roll-up cover attached to them. I don’t notice any issue with pulling side-to-side. Drove it for five hours yesterday and another five today. Couldn’t have been any smoother.
I've had the AUH (along with Demco Autoslider and B&W fixed). If you have a short bed and are tight on payload... then the AUH is a good option. There can still be the ability for nose to meet the cab in a SB with the AUH, depending on nose design, if ground is uneven, etc, but the AUH did me well in my 2500HD CCSB and for a short time in my F350CCSB. BTW - Fort Knox Locks makes a decent king-pin lock for the AUH adapter. The only cons with the AUH (maybe not a con, but was annoying nonetheless) was that many dealers make you take off the AUH adapter - I always had the tools with me, but made the drop off and pick up consume a bit more time. The other was the angle that I had to get the 5er to get over the AUH ball - with these new ford trucks was fairly significant with a lot of popping and creaking. I will say I really liked the Demco Autoslider, it's built like a tank but it rarely left the bed (weights about 300#)... and if you have a long bed, then the B&W fixed is a great option and love that it breaks down into 2 pieces and easily and quickly removed by one person without any tools (have the Ford Puck System).
Denny
Tight enough. Absolutely no chucking with this hitch. The cup is just a cylinder with a spring loaded horizontal pin that prevents the ball from coming out once you're hitched. Per the manufacturer recommendations, I've coated the ball and cup with Slip Plate graphite paint. I can try to grab a close up pic of the cup.
If i was replacing my Reese 20K today I would be giving the PullRight a very hard look plus its all steel and looks to be very well reinforced and the price is right, the Anderson just looks flimsy to me.
Denny
Denny
Yes sir it can. The piece that mounts on the goose ball can be installed in the forward or rearward position before you set the hitch down on it. As you noted, I have a short bed and have it in the rearward position.
https://www.pullrite.com/2600
do you have the factory fifth wheel prep?
is this what you have? The 2600 that attaches to the goose ball connector?
#28
#29
#30
Yes I have the 2600, and the factory fifth wheel prep. I have this https://www.pullrite.com/4437 goose ball for the factory prep. I think the Pullrite goose ball is a superior option as it's a solid ball and doesn't have the plastic lever in the top.
