Driveshaft vibration
Old Aug 28, 2020 | 09:58 PM
  #46
74Mav's Avatar
74Mav
Originally Posted by 2002Ex
This is what my spline looked like. All the coating gone and had a ton of slop up and down. It was not the cause of the vibration.
What was the cause in your case?
Old Aug 28, 2020 | 10:05 PM
  #47
2002Ex's Avatar
2002Ex
Still have not found a solution to my vibration. After carefully observing it, I can feel the vibration at even as low as 20-30 mph and up to 55 when it really kicks in. Then at 65+ it fades and is not really perceptible with these bogger tires.
Old Aug 28, 2020 | 11:30 PM
  #48
74Mav's Avatar
74Mav
I had similar issues. Started with a bad pinion bearing. New bearings, Tru-Trac, wheel bearings, angle shims, new u-joints, rebuilt double cardon, driveshaft trued and balanced - nothing fixed it until I just replaced the driveshaft completely. Tom Wood, $640 for it. No idea for sure if it was the play in the splines or a combination of several things. Just know what resolved the problem.
Old Aug 31, 2020 | 07:36 PM
  #49
Dweber85rc's Avatar
Dweber85rc
Its going back in Friday to a different driveline shop. They asked where I had the driveshaft balanced and rebuilt before and when I told them they oohh... I asked if that was a good oh or a bad oh and the guy I talked to said that they have had to fix work done by the place that rebuild the double cardan and balanced it on more than one occasion. Kinda bummed they couldn't do it until Friday but I wanted them to have the whole truck in case it still a pinion angle issue or something other than the driveshaft still.
Old Sep 4, 2020 | 05:17 PM
  #50
Dweber85rc's Avatar
Dweber85rc
Well it ended up being 2 issues. The rear ujoint that I replaced maybe 700 miles ago this shop said was bad and had 1/8" of play in it. I never felt it when I was pushing and pulling on everything but I don't claim to be a professional. They said the joint I put in was cheap China junk-which was supposed to be one of the better ones at napa- and that they were recommending a spicer unit. So they replaced that and also had to rebalance the driveshaft. I forgot to ask how off the balance was. Anyways no more vibration in the 80 mile drive home. I do have a bit of resonance coming from the exhaust that I never noticed before probably because with the deeper gears the rpms are slightly higher at the speeds I drive and the resonance went away when I kicked it out of overdrive at that speed. Glad to be done with this part of it. Now to get going replacing the rusted out rockers
brettdacosta
Apr 12, 2021 03:42 PM
bigric
Jan 11, 2012 10:09 AM
VTX1800C
Nov 12, 2008 03:12 PM
icy_wolf3
19
Aug 11, 2003 07:11 AM
