Beefy crank main webs
Old Jul 31, 2020 | 12:24 AM
Mitch Huested's Avatar
Mitch Huested
Hello everyone! I'm looking for someone with knowledge of the casting numbers of blocks that can be converted to 4-bolt main caps. I've read 2 articles on the conversion, but the only reference given in the articles is, "First find a block that is condusive to 4-bolt main journal machining." No reference to numbers at all! The block shown has thick flat webs all the way to the oil pan rail. Are there any later model blocks that were built this way?
Old Aug 6, 2020 | 01:16 PM
mcdonaldm's Avatar
mcdonaldm
the early blocks (70-71) are the ones with the thick webs and not all of them have the thick webs. the block casting number is DOVE-A (used in passenger car and cobra-jet cars) but you have to take pan off to see if they have the thick mains or not. i don't know of any late blocks that had the thick mains maybe the D9TE truck blocks but not certain on that one.
Old Aug 6, 2020 | 03:21 PM
85e150's Avatar
85e150
Planning on going over 700HP?
The 460 "cook book":
https://www.460ford.com/threads/460-...-24-09.119213/
Old Aug 10, 2020 | 10:33 PM
Mitch Huested
85e150, planning on going WAY over 700HP! But right now I'm limited by the 2-bolt block. My next build will start with an Eliminator block, but for now I'll have to use a girdle and call it good.
Mitch Huested
Aug 15, 2020 10:06 PM
money pit 69
Jan 16, 2014 04:15 AM
mcribbz
Nov 16, 2005 11:27 AM
kevinupchurch
May 25, 2005 01:57 PM
trinogt
Jan 29, 2003 08:12 AM
