? on crank
Old May 24, 2005 | 09:44 PM
kevinupchurch's Avatar
kevinupchurch
? on crank
i thought i had a d1ve block but when i pulled it it is a c9ve block i have ordered another d1ve will the crankshaft out of the c9ve go into the d1ve without any modifications thanks kevin
Old May 25, 2005 | 08:13 AM
greenhighboy's Avatar
greenhighboy
Yes the crankshaft will fit. Why are you so set on using a D1VE block? The C9 is just as good and probably has a wider oil pan rail and main webs than the D1.
Old May 25, 2005 | 01:57 PM
kevinupchurch
because the c8 is just all rusty and covered in oil by the time i have it bored over and checked and cleaned it was cheaper and easier to just get the d1 already done
