Sponsored by: Real Truck
4R100 Full Fluid Change
Old Jun 14, 2020 | 10:49 AM
antirice's Avatar
antirice
Hi all -
I've read through flush threads involving disconnecting the trans cooler lines, but I stumbled across this video here on the forum and wanted to give it a try if there's no good reason it won't work. Seems like it'd be pretty effective at getting 95% of the fluid changed over pretty quickly and with minimal mess. If this works well, I would figure on full fluid replacement every few standard drain/refill services. Because of my intended intervals, I'm not super worried about the fluid left trapped in the cooler lines at the moment.
The video is for a 5R110, but I wanted to make sure I wasn't overlooking something as to why it wouldn't work on a 4R100.
Thoughts?
- Chris
Old Jun 14, 2020 | 12:43 PM
CousinCarl's Avatar
CousinCarl
I follow @Mark Kovalsky 's procedure: https://sites.google.com/site/woodnt...lush-procedure
Old Jun 14, 2020 | 02:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by antirice
Hi all -
Thoughts?
- Chris
It should work on a 4R100. The pump intake is a different size so you'll need to adjust for that. And this will change the fluid in the cooler lines, too. But I think this one is easier for a 4R100:
https://www.ford-trucks.com/articles...-transmission/
Old Jun 14, 2020 | 05:21 PM
antirice's Avatar
antirice
Mark -
In the readings I've done here on the forum, your advice is generally regarded as gospel. Thank you for taking the time to respond to my question.
I saw your method posted elsewhere, but did not see it in comparison to the method that I posted above. If it's your opinion that the method you linked is faster/easier/less messy/better and is the way to go, then that's the method I'll use.
Much thanks.
- Chris
Old Jun 14, 2020 | 06:41 PM
Mark Kovalsky
The 5R110W method is nothing short of brilliant. It gets around the problem of the thermostat that is in the 5R110W. But the 4R100 does not have a thermostat. So just opening a cooler line will get as much fluid changed as the other method. Either one will change around 95% of the fluid, so it's your choice. I think the older method is just easier to do.
Old Jun 16, 2020 | 09:53 AM
antirice's Avatar
antirice
Mark -
I got the fluid flushed using your method yesterday. Didn't make too much of a mess hooking everything back up when I was done. Thank you for your help!
I did have a question though - since the original recommended interval was 30K, but now we're using Mercon V instead of Mercon - does that change the recommended fluid drain and refill interval?
Thanks
- Chris
Old Jun 16, 2020 | 04:41 PM
Mark Kovalsky
I still think 30k is a good interval to change the MERCON V fluid.
fifty-two_f1
Feb 21, 2011 03:57 PM
Robert6401
Jul 11, 2009 04:21 PM
tag187
Jul 19, 2008 09:02 PM
guessrow
2004 - 2008 F150
Sep 21, 2007 10:43 PM
TN_VOLS
Mar 13, 2007 10:35 AM
