Sponsored by: Real Truck
transmission help
Old Feb 21, 2011 | 02:56 PM
fifty-two_f1's Avatar
fifty-two_f1
transmission help
I am going to change the fluid and filter in my 99 f250 automatic, but was wondering how to get all of the fluid out of the cooler. The book says that it takes like 17 quarts. So I figure if I am going to change it I might as well replace it ALL with new. Any thoughts?
Old Feb 21, 2011 | 03:08 PM
ayden2004's Avatar
ayden2004
most places use a machine to pump all the fluid out. other than that im not sure how else you would get it all out. you could disconect the lines at the cooler and push some air through get the fluid out of there. (just a thought)
Old Feb 21, 2011 | 03:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Duplicate.
Old Feb 21, 2011 | 03:36 PM
Mark Kovalsky
Here's how you can change all of the fluid everywhere in the system. The article could use an update - MERCON V is now the correct fluid.
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old Feb 21, 2011 | 03:57 PM
fifty-two_f1
Thank you for posting that. So I need to use Mercon v? how much is that stuff per quart?
docweld
2004 - 2008 F150
Feb 24, 2013 07:52 PM
monster79f150
May 29, 2011 12:44 AM
redfire42
18
Jun 30, 2008 12:38 PM
brandonsd
Feb 11, 2008 05:32 PM
robbieie
Jan 3, 2004 05:14 PM
