Transmission Fluid
Old Mar 12, 2007 | 10:29 AM
TN_VOLS's Avatar
TN_VOLS
Transmission Fluid
I've got an '02 X 7.3 PSD with the 4R100 tranny. It still has the stock fluid in it and I'm not ready to do a full flush yet. If I do a little towing (4-5 trips with a 6000 pound camper) per year, what fluid type / brand should I be adding that will give good performance and still blend well with the existing transmission fluid that came with the truck from Ford?
Old Mar 13, 2007 | 07:32 AM
Casey's Avatar
Casey
Any fluid that has a MERCON rating will work fine.
Old Mar 13, 2007 | 10:35 AM
aklim's Avatar
aklim
You are already there when you change fluid so why not drain the TC? If you don't want to, you don't have to unhook the cooler lines and blow them out. I'd use Amsoil. Also look into getting a 6.0L Cooler for the trans.
ViLo
1983 - 2012 Ranger & B-Series
Dec 15, 2012 12:13 AM
B 3000
Escape & Escape Hybrid
Feb 18, 2010 06:41 PM
sfafarley
2004 - 2008 F150
Aug 7, 2009 06:41 PM
Psychoboys
Apr 2, 2006 08:36 PM
ralphnaderrules
General Automotive Discussion
Nov 5, 2004 05:14 PM
