THROTTLE POSITION SENSOR REPLACEMENT
Old Jun 5, 2020 | 07:13 PM
ehusmann's Avatar
ehusmann
Have a 1993 F150 5.0L on which I'm going to replace the throttle position sensor (TPS). The factory manual says to scribe the TPS and throttle body for alignment on re-installation. The TPS has two tabs and the throttle body has a flat shaft. Question is how does the scribe instruction play with a new TPS? Thanks
Old Jun 5, 2020 | 08:33 PM
KILTSON412's Avatar
KILTSON412
I just replaced mine. Its spring action I believe. If ita like the 4.9l just line it up pointing a little down and twist it up clockwise to line the bolts up
Old Jun 5, 2020 | 08:34 PM
KILTSON412's Avatar
KILTSON412
I did it with my throttle body on. Works fine
Old Jun 5, 2020 | 08:43 PM
gaj0137's Avatar
gaj0137
There is no need to scribe it since its not adjustable. Just swap in a new one and it will work fine.
Old Jun 6, 2020 | 12:55 PM
torq'ta 5 8's Avatar
torq'ta 5 8
If you didn't get a motorcraft TPS, I would check minimum closed voltage is meet, and minimum/maximum resistance is also meet
Throttle Position Sensor Testing, Replacement and Adjustment | Full Size Ford Bronco Forum
BigBlue92
Mar 7, 2025 08:39 AM
Neo64
Aug 25, 2019 09:44 AM
frankyford
Nov 23, 2007 10:58 PM
jzman7
Oct 3, 2007 07:17 PM
chuckles738
Feb 3, 2003 03:11 PM
