2001 Excursion 4x4 not working
Old Jun 4, 2020 | 08:35 AM
sdbuggyboys's Avatar
sdbuggyboys
'01 Excursion 7.3l 4x4. Four wheel drive won't engage, no light on the dash. I've replaced/check all the fuses, replaced the ESOF solenoid, the transfer case motor, the dash switch, and the relays. I can actuate the relays with a power probe and shift the motor, and I have continuity between all the transfer case wires from the t-case all the way to the firewall. I have power to the relays in the correct pins, and good grounds. I removed the GEM module and everything looks completely fine inside, all the connections are good. What else could it be? The Excursion GEM modules are pretty expensive, so I don't really want to keep throwing parts at it, but I don't really know of anything else to check. It's got manual hubs and I've blocked off the vacuum lines, AC mode switch works fine so no vacuum leak. Any help would be greatly appreciated!
Old Jun 4, 2020 | 01:07 PM
neilc88's Avatar
neilc88
I'm having the same issue. Struggling to find the problem.
Old Jun 7, 2020 | 04:20 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Drop by the 7.3L PSD Tech Folder under the "Axles & Hubs" section. Look for ESOF Diagnosis MY 2000 part 1 & 2. They are pin point tests taken directly from the Ford Service Manual.
Old Jun 7, 2020 | 08:09 PM
neilc88's Avatar
neilc88
The link is great for OP. I have an 2002 V10 gas. Would all that be the same for me? Or do you know of the V10 link?
thanks.
Old Jun 8, 2020 | 12:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It is different for the 02-05 trucks. Ford changed up the junction boxes, and they did away with the GEM module that came on the 99-01 trucks. The 4x4 wiring all went through the old GEM module, which is what is in that tech thread Sous linked to.
Old Jun 8, 2020 | 01:23 PM
sdbuggyboys
This is an '01, so it still has the GEM module. I've seen bits of that link before, and I've done a point to point test on most of it. I'll look through that link and see if i've missed anything.
Old Jun 8, 2020 | 07:54 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
With no light on the dash, that indicates the transfer case is not shifting...or the GEM module is not getting the voltages that indicate it shifted.
Old Jun 9, 2020 | 07:05 AM
sdbuggyboys
Yeah, its definitely not shifting. I can shift it by applying grounds to the relay's but the GEM module is not commanding the shift. So, either it's not sure if its in 2 or 4 and therefore doesn't shift, or its not getting any information because the GEM is dead. I took it out and all the connections look totally fine and the board doesn't have any burn marks on it. I have continuity between the shift position sensor and the firewall connector, and between the relays and the gem module, so its either a broken wire between the firewall and the GEM or its a bad GEM. I just wanted to make sure I'm not missing anything before I order/reprogram the GEM.
Old Jun 9, 2020 | 06:37 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The GEM won't send the shift command unless it knows what state the xfer case is in. Make sure you have good reference voltages that the GEM is looking for to determine that.
Old Jun 10, 2020 | 07:01 AM
sdbuggyboys
True, I'll check. The motor is brand new, and I have continuity, but I'll check for those to make sure. Without pouring through the manual again, do you know what they're supposed to be off hand?
Old Jun 10, 2020 | 10:58 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Pull codes from the GEM, or run through the operational check I posted in that troubleshooting thread. Where you at in TX?
Old Jun 10, 2020 | 12:16 PM
sdbuggyboys
We ate between San Antonio and Austin. Last I pulled the codes I had a P1828, P1820, P1876,and P1832. However, that was before I discovered that the relays were wired wrong/had pins pulled out. I haven't checked since I got the motor to actuate by overriding the relays
Old Jun 15, 2020 | 03:31 PM
sdbuggyboys
Sorry for the delay, finally got my snap-on back from the guy who borrowed it. If I command the relay through the GEM, I can hear the motor run, and it locks into 4wd. I also tested the indicator light just to make sure and both 4 and low show up. So, my guess is it doesn't know what state its in, and therefore won't shift. Its a brand new motor assembly, so does that mean I have something wrong in the connector or harness?
Old Jun 15, 2020 | 08:23 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'm in the Canyon Lake area if you want to PM me. I actually have a couple days off coming up...
2006fordf25060
Feb 4, 2019 12:10 PM
id_birdhntr
May 7, 2013 07:39 PM
g8trowwd
1997 - 2003 F150
May 27, 2012 05:57 PM
Enginetech88
Dec 28, 2011 11:36 PM
Ron Mantz
Dec 16, 2009 07:42 AM
