Sponsored by: Auxito
2002 shift on fly 4x4 problems.
Old May 27, 2012 | 10:38 AM
g8trowwd's Avatar
g8trowwd
4th Gear
I have a 2002 F150 with the Shift on the Fly system and my 4 High light stays on but the case will not go into 4x4. Here is what I know so far.
  1. I pulled the electric motor from the back of the case and the indicator is pointing to 2H. I can easily move the transfer case through 4H and 4L by hand. I do not think the case is in 4H nor will the motor activate to send it there.
  2. I do not see any voltage spike across the orange and yellow wire of the transfer case motor when I have someone flip the switch.
  3. I do not feel any "click" from the solenoids when the switch is thrown.
  4. the connecting rod on the axle vacuum is pulled in
  5. I cannot find the electric switch/sensor on the T-case that is on the manual cases. I do have either a vacuum line or a vent tube coming from the front driver's side of the case. I would guess this is different due to the manual vs shift on the fly cases.
  6. I have not found any blown fuses.
Most of the 4x4 thread speaks to the manual case so at this point it seems I have some type of ECM problem. Thanks for any input or help towards my problem solving attempts.
Tim
Old May 27, 2012 | 05:57 PM
Bluegrass 7's Avatar
Bluegrass 7
Not an ECM but a GEM module.
The GEM lights the light.
If you have no action when the dash switch is operated, my bet is on the GEM, at this point.
It's located behind the dash fuse block.
It is a programmed unit so needs to be the same and have the same program in it for replacment.
Check for a windshield leak while you in the area, dropping water in the module.
Good luck.
liv2roc
1997 - 2003 F150
Dec 14, 2018 04:50 PM
NotEnoughTrucks2014
1997 - 2003 F150
Nov 10, 2017 07:20 AM
DevilsF150
1997 - 2003 F150
Apr 25, 2016 08:09 PM
slowstang
1997 - 2003 F150
Dec 11, 2015 08:32 PM
87thhunter
Jul 14, 2014 04:21 PM
