EBP sensors
Old Apr 23, 2020 | 02:55 AM
FDB's Avatar
FDB
EBP sensors
Would anyone know what a EBP sensor should read on a Scangauge with KOEO. I have one that reads 13.9 and another reads 33.6. I would think it should be zero. Thanks
Old Apr 23, 2020 | 04:11 AM
FinnishStroker's Avatar
FinnishStroker
I think it should read 14.7 psi at sea level.
Old Apr 23, 2020 | 07:42 AM
Walleye Hunter's Avatar
Walleye Hunter
What FinnishStroker said. equally important is that it is within close range of what the MAP reads. I can't remember how close they should be though, maybe within .5 of each other?
Old Apr 23, 2020 | 09:11 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
I thought the map sensor was supposed to read 14.7? My ebp and boost are always within .5 of each other while running down the road. The map is usually 3X a higher value than the ebp and boost. I’m gonna have to check my koeo readings later this evening.
Old Apr 23, 2020 | 09:23 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
MAP and boost are NOT (see correction below, my mistake) the same measurement.
Baro, MAP and EBP should be within .5 of each other on a cold engine with the key on and engine off. Whichever one of those is not like the others is indicated to be faulty. Baro is internal to the PCM on most of the 7.3L PSD's and is rarely the suspect faulty sensor. I forget which MY had an external Baro sensor, maybe the E99's?
While running down the road, the desire to have a 1:1 ratio between MAP and EBP is optimal. A turbo system that creates too much EBP when boosting is creating excess pressure and heat.
FDB, did you purchase a Motorcraft EBP sensor? Did you clean the tube that runs from the sensor mount to the exhaust manifold before running the scan?
Old Apr 23, 2020 | 01:47 PM
Walleye Hunter
Originally Posted by Sous
MAP and boost are the same measurement.
Are you sure about that? I thought that boost=MAP-Baro.
Old Apr 23, 2020 | 02:07 PM
FDB's Avatar
FDB
Mine is also E99, no codes or problems, just checking numbers with the ScanGauge. The tube is clean. Apparently the 13.9 sensor is correct. I,m assuming the PCM is getting BARO from the MAP in KOEO like the gas rigs. Thanks
Old Apr 23, 2020 | 02:17 PM
Sous's Avatar
Sous
FTE Emeritus
Let me double check... I'll be right back...
EDIT: You were right and this was my first instance of being wrong today, so I am glad it was here in the virtual world instead of something else I have to fix in the real world.
Boost
(AKA Manifold Gauge Pressure)
Short Name: Boost
PID: 221440
Units: PSI
Max/Min: 30.0/0.0 (stock) 40.0/0.0 (performance)
Equation: (((A*256)+B)*0.03625)-[221442]
"-[221442]" subtracts the Barometric sensor (located on the PCM on some trucks, external on others) reading from the MAP reading - and this gives you just the boost pressure above atmospheric pressure.
Source: https://www.ford-trucks.com/forums/1...l#post16005729
I made the assumption that since a mechanical boost gauge can be tapped into the spider or Y-pipe which is similar to where the MAP sensor is tapped into via a hose that they were the same measurement/reading. I assumed wrong and have gone back to edit my original incorrect statement.
Old Apr 23, 2020 | 02:25 PM
bigb56's Avatar
bigb56
Which brings to mind a question I have always wondered about, if a man speaks and there is no woman around to hear him is he still wrong?
Old Apr 23, 2020 | 02:32 PM
CousinCarl's Avatar
CousinCarl
Are you calling Mark a woman?
Old Apr 23, 2020 | 02:34 PM
Sous's Avatar
Sous
FTE Emeritus
Absolutely because they hear everything and what they don't hear the somehow know about...
My wife is very forgiving when I make mistakes. Although I am typically very hard on myself and sometimes make another mistake following the first mistake depending on the severity of the first mistake.
It happens, none of us are perfect and I will probably make another mistake today, plenty of time left... Yesterday when making our homemade Big Macs (click this link for picture) I had intentions of making 2 Big Macs and a Mac Jr. Well, because I am a jackass sometimes I had food on my brain, I failed to count to 5 and only made 4 patties. Which made 1 Big Mac, 1 Mac Jr. and left a patty to fend for itself. Luckily though this was a first world problem because the Big Mac was YUUUUUUGGGEEEE and was enough of a challenge to eat by itself, let alone the sweet potato fries next to it.
Sorry for the thread derailment, but maybe it will bring some laughs to someone out there that just made a mistake...
Old Apr 25, 2020 | 07:01 AM
Walleye Hunter
There IS a thread for this! But I am the same way. I am far from perfect and often do things when I know better and when I make stupid mistakes I'm mad at myself for quite a while.
Rumble phish
2004 - 2008 F150
17
Dec 20, 2018 09:09 AM
68firebirdman
Apr 4, 2018 08:31 PM
Jnowaczyk
Modular V10 (6.8l)
Nov 6, 2013 01:02 PM
mvimpvm
Jun 23, 2004 10:01 PM
jasmo
1997 - 2003 F150
Jun 5, 2004 01:36 PM
