oxygen sensor reading--what is normal?
Old Apr 26, 2004 | 10:00 PM
mvimpvm's Avatar
mvimpvm
What is the normal oxygen sensor reading? I am having trouble with missing under load. When I read the sensor with my autoxray it bounces all around never settling down and reads invalid about 1 out of every 3 measurements. What is the normal voltages and under what circumstances?
Old Apr 27, 2004 | 07:22 AM
EPNCSU2006's Avatar
EPNCSU2006
In closed loop, the O2 sensor should switch from lean to rich over and over. The voltage will bounce between about .4V to around .7V.
Old Apr 27, 2004 | 10:37 AM
jimandmandy's Avatar
jimandmandy
What you dont want is a steady .5v reading. That means it is dead.
Jim
Old Jun 20, 2004 | 01:55 PM
ezacarias's Avatar
ezacarias
how do you get the oxygen sensor reading voltage?
Old Jun 23, 2004 | 09:48 AM
mvimpvm's Avatar
mvimpvm
Easiest and cheapest way is to go to your local auto parts store that rents a code reader. You will need something that not only reads the code but you can monitor the data in real time. I bought an AutoXray unit that does both well. Another option is ebay.
Old Jun 23, 2004 | 10:01 PM
broncobasher's Avatar
broncobasher
You can read the o2 with a multimeter. It is normal for the voltage to bounce around. It also reads 0 volts when it hits like 0.42 volts. Unsure the exact crossover point. The o2 is a voltage generator, so once it is up to temperature, you can unplug it and still get a reading. If it is not bouncing around from .4 to like .7 as EPN said , you have a problem.
wikdwest
Jul 20, 2014 01:54 PM
wikdwest
Jul 19, 2014 12:12 AM
xc4jokestomper
Dec 9, 2011 07:45 AM
rbrackett807
1997 - 2003 F150
Sep 27, 2011 10:43 AM
