Modular V10 (6.8l)
O2 question
Old Nov 4, 2013 | 05:23 PM
Jnowaczyk's Avatar
Jnowaczyk
O2 question
Sensor 1 bank1 Was staying on lean
Sensor 2 bank 1 was flopping rich to lean as it should
Replaced sensor 1 bank 1. Now it switches lean to rich not fast and truck runs like ****. Sensor 2 bank one now suck on lean. And is new.
Runs but not full power with with sensor 1 bank 1 un hooked.
No cat no leaks. No misfires. 99 f250 sd. V10. .
I have another posting here on what's been done
https://www.ford-trucks.com/forums/1...-v10-help.html
Old Nov 5, 2013 | 12:03 AM
Zedrive's Avatar
Zedrive
You should be dealing with a OBD1 emissions which would have bank 1 sensor 1 and bank 2 sensor 1. In your other thread as well as here you reference a bank 1 sensor 2 (post CAT catalyst monitor). To my understanding the California trucks were fitted OBD II not something I'm certain of just read it here on FTE.
Your code reader wouldn't show a signal for a sensor 2 unless it was OBD2 so maybe something is plugged in wrong after someone remover the CAT.
Or maybe it's just a typo and I just wasted lots of words.
Good luck.
Old Nov 6, 2013 | 12:26 PM
Jnowaczyk's Avatar
Jnowaczyk
I may of said it wrong lol. We're talking both upstream sensors. Sensor 1 bank one pass side
Sensor 2 bank 1. Drivers side. Both upstream.
When sensor 2. Is pluged in works fine as long as sensor 1 bank 1 is unpluged. Runs ok but not right. When sensor 1 bank 1 is pluged in. Sensor 2 bank one does not switch and sensor 1 stays rich and floods the truck. I hope I said it right this time.
Old Nov 6, 2013 | 12:54 PM
projectSHO89's Avatar
projectSHO89
The correct nomenclature is bank 1 (passenger side) bank 2 (driver side) and sensor 1 (upstream) and sensor 2 (downstream)
Therefore:
B1S1=Passenger Upstream
B2S1=Driver Upstream
B1S2=Passenger Downstream
B2S2=Driver Downstream
Downstream sensors are ONLY on the OBDII vehicles but not on OBD1 Super Duty trucks. Some OBDII variations may have only a single downstream sensor. Downstream O2 sensors are only there to monitor converter performance.
Old Nov 6, 2013 | 01:00 PM
Jnowaczyk's Avatar
Jnowaczyk
Therefore:
Ok b2s1. Works like it should as long as b1s1 is unplugged. When b1s1 is plugged in b2s1 does not function correctly. Stays lean while b1s1 switches but stays rich for so long it floods the truck
Old Nov 6, 2013 | 01:02 PM
Jnowaczyk's Avatar
Jnowaczyk
So can anyone tel me where to look to correct the problem. I'm guessing the pcm. .
foxykool
Exhaust Systems
Jan 4, 2010 11:24 AM
V10_Cougar
Modular V10 (6.8l)
31
Sep 26, 2007 12:12 PM
beefster
May 24, 2006 05:06 AM
rgreen01
Jan 3, 2005 12:25 PM
lds
1997 - 2003 F150
Nov 4, 2003 06:30 PM
