C6 swap from e4od
Old May 15, 2020 | 01:45 PM
  #61
genscripter's Avatar
genscripter
I missed this thread in the last few days. For anyone who wants a visual on what they are talking about, I made this image for people who were asking me about VRV installation from a E4OD or Manual to C6 swap, like the OP did.
The rod needs to be slightly smaller than the concavity of the cam, but not too small that the cam will slip off it. Also, the inner diameter is around 0.09in.
Old May 15, 2020 | 01:48 PM
  #62
genscripter
Also, you can see the difference in the throttle connectors from the E4OD and C6 in my Injector pump replacement video (below). Go to around minute 5:50 to see the IP's next to each other on my bench.
Old Jul 10, 2020 | 02:14 PM
  #63
Edward Michael's Avatar
Edward Michael
This thing is running like my old 97 powerstroke up the mountain!-).
In drive the whole way. The 86 is in 2nd gear, so we’ll have some work on it soon.
However, it is stalling after a rev of the pedal or hard acceleration and quick removal of fuel pedal pressure.
this was not the case when we first started it up. We could rev it and the engine resumed a nice idle.
since have installed rebuilt bb code injectors from Mylex and a new fuel line return kit. No leaks!-)
maybe vacuum?
Old Jul 10, 2020 | 02:37 PM
  #64
tjc transport's Avatar
tjc transport
i ain't rite
nope. the stalling sounds like idle is too low. idle should be around 650-750 in park.
Old Jul 10, 2020 | 02:50 PM
  #65
DarkOverCast's Avatar
DarkOverCast
Govenor droop adjustment could also need to be tightened up.
Old Jul 10, 2020 | 04:20 PM
  #66
Edward Michael
Had to turn idle up to 800 per truck gauge before stopping the hesitation. 6-700 stopped stall but a hesitation was happening.
Any procedure for governor tighten up?
thank you and Best Regards!-)
Old Jul 10, 2020 | 06:23 PM
  #67
lonewolf_'s Avatar
lonewolf_
Scope Wizard
see the Stanadyne Service Bulletin SB 97R4 .... think I've posted it here before...
Old Jul 10, 2020 | 06:47 PM
  #68
Chevy_Eater's Avatar
Chevy_Eater
maybe vacuum?
I had one that did that when I first got it, turned out the fuel filter was full of water.
Old Jul 10, 2020 | 09:39 PM
  #69
jjqllc's Avatar
jjqllc
My '87 was doing that after I put on a new pump. I had to advance the timing a bit IIRC.
ol'blue91
Dec 13, 2009 05:13 PM
CantDrive55
Aug 20, 2007 08:18 PM
89ford73
Jul 17, 2007 01:20 PM
havi
Jan 28, 2007 11:29 PM
Shiny62
Sep 25, 2005 05:18 PM
