C6 swap from e4od
Old Apr 17, 2020 | 01:46 PM
tjc transport's Avatar
tjc transport
i ain't rite
thank you lonewolf.
i am suffering from sleep deprivation and can't remember crap the past few days.
72 hours up, 4 hours sleep, then another 24 hours up. 4 hours sleep this am and then the sun woke me up again.
if the sun is up, i am too. even if the room is blacked out, my brain still will not shut off.
the night job is finally done so after tomorrow morning i should be back to normal.
Old Apr 17, 2020 | 01:57 PM
Edward Michael's Avatar
Edward Michael
Okiedokie!-) no biggie as looks like the fresh oil change is dripping pretty good from the rear main.
any idea’s on driving it without the flex plate. Run through the trans as it was purchased used and be nice to see it and torque converter at working.
Thanks
Old Apr 17, 2020 | 02:25 PM
tjc transport
i ain't rite
if you have a cast flywheel you need that plate. if it is a thin steel flex plate like gas engines use, you only need the small reinforcing plate that goes around the crank flange.
Old Apr 17, 2020 | 02:42 PM
Edward Michael
Oh well. B.B. bbbummer.
Thought i might run the trans a little to see it working.
so will drop trans and add that part and get to work on the rear main.
thanks for the support
Old Apr 17, 2020 | 03:06 PM
Edward Michael
What flywheel is this?
Is this the thin one that requires the flex plate?
Thanks
Old Apr 17, 2020 | 04:58 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
if it looks like this ... then it needs it....
the parts on the RH side replace the 2 piece Flywheel/flexplate
Old Apr 17, 2020 | 07:42 PM
Edward Michael
Hmm. Seems like we have to remove the trans to see for sure.
Old Apr 17, 2020 | 08:11 PM
Edward Michael
And thank you for the info!-)
does this bolt to the flywheel with the flywheel bolts?
is it required on an e4od?
These 2 are yes than its still there.
thanks
Old Apr 17, 2020 | 08:13 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
well, your pictures seem to show a Cast Iron Flywheel... if that is true then it needs the flexplate.
Old Apr 17, 2020 | 08:20 PM
Edward Michael
Okiedokie!-)
Does it attach with the flywheel bolts?
when we dropped the e4odisaster, we did not remove the flywheel.
so...regardless of flywheel, these parts are presumed there.
Old Apr 17, 2020 | 09:29 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
E4OD generally has 6 Studs on the Torque converter for diesel... while the E4OD on Gassers often had only 4
I have no Idea what you had to start with... but to answer the Question ...Yes the flexplate bolts on with the flywheel bolts into the crankshaft.
AS I said generally 6 studs.... but https://shiftritetransmissions.com/s...smission-e40d/
Old Apr 17, 2020 | 09:56 PM
Edward Michael
Okiedokie!-) cool.
thank you.
Old Apr 17, 2020 | 11:47 PM
  #28
lonewolf_'s Avatar
lonewolf_
Scope Wizard
looking at my 93 F250 which has the 6 bolt converter it seems that most really had the 4 bolt converter with the 2 piece flywheel assy... for the E4OD.. interesting
Ford probably didn't start using the 6 bolt converters until the PSD Mark Kovalsky would know more about that than I
I know my converter is Gold and I know Ford Never painted converters so mine is not OEM.
Old Apr 18, 2020 | 12:43 AM
  #29
Edward Michael
I bought this 90 F250 7.3L supercab with a non functioning e4od.
pulled it last year and it sat idle. Friend asked for some work to buy diapers and formula for the kids....
he was learned hot rodder (chevy’s)_.. and trained usmc mechanic (some ginormous vehicle)....
....”c6 4x4 trans instal.. no problem”...
back to it now and fixed the PO hot wired push button start and sometimes working glow plugs....
....broken ignition actuator and stripped out steering wheel puller threads...finally got some all thread to
weld to the steering wheel.l. Took awhile and when reassembled start wasn’t working.... tjc turned us onto neutral safety switch and we realized the tranny is up there but nothing hooked up. Lol.
The transfer case used has the wrong hookups for the linkage. Will end up with the 7.5L c6 transfer case.
hope it works. Only have a front driveshaft right now. Pic n “crush” yard moves everything with fork lift without
removing driveshafts~!-)
the rear main seal leak is actually a fuel leak....hello return lines!-)
all in all...this week.. its pretty cool to go out to the truck, open the door, turn the key, hear the glow plugs
fire and start it.
Old Apr 18, 2020 | 01:22 AM
  #30
lonewolf_'s Avatar
lonewolf_
Scope Wizard
return line leak is probably better than having to do the rear seal
my truck sees a lot of Hiway driving between TX and WV so I really like the E4OD with the 3.55 gear axle when I had a C6 in an older 83 I was always looking for another gear......
if ya don't do a lot of long range driving the C6 is fine
AND yeah TJC Transport I know the sleep deprivation thing .... I can't remember when I last got more than a couple hours sleep in one session .... I think it's old Farts disease at least for me ????
